7.3 Excursion lower rad hose: straight or curved?
Old Jan 2, 2025 | 05:18 PM
oharal's Avatar
oharal
Discovered a leak from the lower rad hose today. While shopping Rock Auto I see lower hoses described as straight or as curved. I think I need the straight? But the pics can be so misleading. This is one of those cases where it should be 50/50 but in reality woupd be 90% probability I get home with the wrong part. Any advise is appreciated! Truck details in signature.
Luke
Old Jan 2, 2025 | 05:25 PM
RA101725's Avatar
RA101725
Banned
Depends on which water pump inlet you have. Earlier engines had curved inlet and straight hose and later ones had straight inlet and curved hose.
It might just be loose from colder weather. Does it have the stock pinch clamps on it?
Old Jan 2, 2025 | 05:33 PM
oharal's Avatar
oharal
Someone put worm clamps on it before my time which was 80k miles ago back in 2017. Ive never had an issue with it in that time. It was cold overnight but warm today. I spent some time in the sun while I was out in the wild driving it today and it felt nice without a jacket in short sleeves. These hoses are old for sure. My pump exits in what id consider straight, something between 3 and 4 o'clock
cleatus12r's Avatar
cleatus12r
Butt-Head
It depends on your current water pump.
If the inlet is a 4" long straight piece, you need the curved hose. If the inlet is a long curved one, you need a straight hose.
Old Jan 2, 2025 | 05:38 PM
RA101725's Avatar
RA101725
Banned
That's the newer style straight inlet. Those worm gear clamps are kind of flimsy. Might just need to tighten it a bit.
Riff-raff makes an aluminum straight inlet and silicone hoses if you feel like spending money. Looks like you've already got the aluminum thermostat housing.
Old Jan 2, 2025 | 05:40 PM
oharal's Avatar
oharal
Yeah I tried loosening and moving the clamp some and cranking it back down and its still leaking so probably time to replace the hose.
does that mean I need a "straight hose" or a hose for the straight inlet? Cleatus made it sound like straight for curved pump, curved for straight pump?
Old Jan 2, 2025 | 05:43 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Curved hose for straight inlet.
The one you need
The one for a curved inlet:
Old Jan 2, 2025 | 05:45 PM
RA101725's Avatar
RA101725
Banned
You've go the curved hose and straight inlet, which is the updated design being that your truck is a 2002
I'd clamp the hell out of it unless you want to drain the rad which is a little bit of a pain.
CatD2
Mar 19, 2022 09:36 AM
MsKitty
Jun 19, 2021 01:51 PM
sunuvabug
Aug 24, 2017 07:31 AM
turboboost
Apr 5, 2012 05:23 AM
1979f_100
Aerostar
Sep 11, 2009 12:38 PM
