2020+ Explorer Discuss the rear-wheel-drive 2020+ Explorer
4WD 2024 Explorer, Timberline
Old Dec 23, 2024 | 01:19 PM
2019f350's Avatar
2019f350
There is nothing to put the vehicle into "4 wheel drive". I know, it's all wheel drive. Our driveway is steep and I want every advantage for the Mrs'.
There is a drive mode **** that changes from: normal, eco, sport, slippery, rainy, deep sand/snow. Does deep sand/snow essentially put it into 4WD? Traction control can also be turned off/on. Thanks
Old Dec 24, 2024 | 11:12 AM
2020FordRaptor's Avatar
2020FordRaptor
The different drive modes just adjust traction control sensitivity, throttle response, and other little things, I don’t think it changes the behavior of the AWD system. And it is an AWD system and not 4wd.
Old Dec 28, 2024 | 04:03 PM
2019f350's Avatar
2019f350
On the lower right side of the rear hatch is an emblem "4WD". How if anything does this make a difference?
What about the "traction control" button? Is the computer supposed to be smarter? Is that something only to turn off after getting stuck, in an attempt to "rock your way out"?
Thanks
Old Dec 29, 2024 | 11:04 AM
2020FordRaptor
Thanks
These cars are technically AWD but Ford advertises it as Intelligent 4wd. It makes a huge difference because if it wasn’t AWD it’d be RWD and probably worse in snow. You could turn traction control off to rock your way out, otherwise unless the traction control is stopping you power wise of getting you out, it usually helps by not just letting the tires spin.
Rob89
Dec 10, 2017 05:49 PM
taco1972
1997 - 2003 F150
Jan 16, 2013 11:09 PM
dg121652
Feb 1, 2005 12:21 AM
hondo25
Apr 10, 2003 09:43 PM
patrick k
Escape & Escape Hybrid
Nov 18, 2001 12:09 PM
