A Guide to Properly Diagnose Contamination and Repair Diesel Fuel Systems
Old Dec 22, 2024 | 04:41 PM
speakerfritz's Avatar
speakerfritz
interesting read..hope we will never need it
https://static.oemdtc.com/GSB/G0000096.pdf
Old Dec 22, 2024 | 06:08 PM
FishOnOne's Avatar
FishOnOne
Copy/Paste from the Q&A section
Fuel additives that emulsify water reduce the effectiveness of the DFCM to separate water must not be used.
Old Dec 27, 2024 | 10:21 AM
acdii's Avatar
acdii
Hot Shots Secret demulsifies water. Was just reading the label on it.
Old Dec 27, 2024 | 11:07 AM
Overkill2's Avatar
Overkill2
I'll stick with K100D as it chemically bonds with water forming a permanent solution with it, at the molecular level... an emulsion is a temporary mixture. I don't care what that manual says, I've got 131k miles now using K100. I refuse to believe, that living in a cold weather region in winter, that K100 has not helped me with condensation that likely forms on the inner walls of the fuel tank as the return fuel warms the tank fuel, so the cold air on the outside with the warmed inside of my fuel tank has to cause water droplets to form on the walls and get into the tank fuel. I normally only let my tank get down to half full, but there has been exceptions when time and circumstances have taken the tank lower than that to about a quarter tank, but like the water my Mishimoto oil catch can collects from the warm engine oil in winter and even similar to a house window where the cold air meets the warm inside surface of the glass, us fellas in the rust belt have to have water forming on the insides of the fuel tank walls where exposed and not covered in fuel when we get to where we are driving to and shut of the truck. Just my 2 cents... YMMV....
Think outside the box – Cuestión de Ideas
speakerfritz
6.7L Power Stroke Diesel
Dec 21, 2021 03:20 PM
dipalda
22
Dec 23, 2020 12:17 PM
WatsonR
Jul 15, 2014 09:42 PM
tcbaldmtn
Aug 5, 2004 03:04 PM
