1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
temperature sending unit access
Old Sep 22, 2024 | 12:07 PM
sgt1022's Avatar
sgt1022
2nd Gear
Hello I'm new to the forum. I have a 1963 Unibody with a 292. This is my first foray in to Y blocks. I have a temp sending unit in the passenger cylinder head for my Dakota digital gauges. I have not found another accessible port it install the thermostatic switch for my electric fans. Is there another one on the motor somewhere?
Old Sep 23, 2024 | 05:56 PM
FarmMotorSports's Avatar
FarmMotorSports
IF I remember heads can be swapped left to right. So you're other head MAY have a plug where you can install one.
May..... I believe some were never drilled and tapped....
It's been 15 years since I had a Y block... So check diagonal across the motor on the other head....
Old Sep 23, 2024 | 05:59 PM
sgt1022's Avatar
sgt1022
2nd Gear
thanks I’ll check
Old Sep 24, 2024 | 02:03 PM
7BercMerc's Avatar
7BercMerc
On my 64 and 62 and a couple other spare Y Blocks I have sitting around there is a tapped hole just in front of the oil filter. It's about in the center of the block, front to back. Mine are all connected there.
Old Jul 3, 2025 | 09:14 PM
Patillac707's Avatar
Patillac707
3rd Gear
I had the same problem
habbythetabby
Apr 7, 2023 09:29 AM
habbythetabby
Jan 8, 2023 08:35 AM
roadrunner01
Sep 26, 2020 01:04 AM
iontkendall
Nov 11, 2007 06:45 AM
