Sending unit
Old Sep 23, 2020 | 07:21 PM
roadrunner01's Avatar
roadrunner01
Sending unit
In my 49 I had the thermal switch fail the other day, I had one and remembered I had another set if flathead heads with sending unit/ thermal switch.
i pulled them out and installed into my truck, sending unit worked bit read cooler than it should due to being gunked up. I pulled it today and soaked it in fleet guard restore on stove top at approximately 212f for 90 min. It cleaned it as new looking, but now temp gauge goes all the was to C and doesn’t move until the key is off and goes to H as it should.
Im letting it sit overnight to see if it will work in am, what could have happened cleaning to cause it to fail? I prefer the vintage unit over the reproductions available currently.
Old Sep 24, 2020 | 09:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It sounds like the sending unit is just bad. The soaking may have caused the material in the bulb to leak out. There's no fixing them.
Old Sep 24, 2020 | 10:26 AM
Mixer man's Avatar
Mixer man
I don't believe those sending units are actually liquid tight in the first place. Chances are the heating while submerged allowed expansion of the joints and the Fleet Guard leaked in and shorted the contacts. You can try heating again not submerged and see if the liquid seeps out, but I think it's done for.
Old Sep 25, 2020 | 06:21 PM
roadrunner01
Sorry for the late reply, I had no idea the sending units were liquid filled. Thanks guys
Old Sep 25, 2020 | 10:19 PM
Mixer man's Avatar
Mixer man
That's a new one on me too. I always assumed they were dry-bulb units considering the electrical components. I wonder what liquid is used that would be non-conductive?
Old Sep 25, 2020 | 11:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've never cut one open, but I assumed there was something to help transfer coolant heat more directly to the bimetal. The more I look at the drawings of them the less I understand how they work.
Old Sep 26, 2020 | 01:04 AM
Mixer man's Avatar
Mixer man
It's been my experience with marine instrumentation that all liquid filled temperature indicators are either direct reading (bulb thermometer) or indirect reading (wet bulb - connects to a gauge via a capillary tube, or a dial indicator via linkage). The bulbs are either directly submerged or installed in a well that is filled with a graphite paste to transfer heat from the well wall to the bulb without any loss. So I'll stand by my original assessment that the sending unit took a big gulp when submerged and heated, and failed. You MAY be able to save it by carefully drilling a pinhole in the top corner of the phenolic cap, hang it upside down and heat it up with a heat gun to see if it will drain.
bradphx
Sep 26, 2016 12:43 PM
hugger94
May 21, 2009 12:01 PM
vanHoy
13
Feb 22, 2009 08:48 PM
