2022 6.7 F350 10 speed trans filter change
Old Aug 5, 2024 | 12:42 PM
Readgriff's Avatar
Readgriff
What is the MotoCraft Trans Filter part number for the Super duty 2022 6.7 10 speed.Is there any other filters I need ti replace on the trans? How many quarts of fluid do I need at what type? Thanks Dave read
Old Oct 30, 2024 | 03:44 PM
Dustin F450's Avatar
Dustin F450
12 quarts of ulv will do it. Get the filter AND a new pump seal from your dealer. It's an easy job. Suck out the fluid from the fill hole, drop the pan, replace pump seal and filter, install pan, use a torque wrench to tight bolts, add fluid through the same hole you sucked it out of earlier...until it just drips, start it up, go through the gears, check with engine running, get it to 195-215 * pull the plug again and let it dribble out until it is even with the bottom of the fill plug....with the truck running..DONE
Motohead911
Sep 2, 2022 08:20 AM
BWST
37
Dec 2, 2013 10:28 PM
jaycenk
Mar 7, 2013 01:32 PM
ryanf250
Oct 30, 2012 12:02 PM
marthur9789
20
Jan 9, 2011 04:38 PM
