Back up camera
Old Oct 29, 2024 | 01:19 PM
Rgoeke65's Avatar
Rgoeke65
1st Gear
Back up camera
So having some issues with my back up camera. Not co.ing on and has the message see dealer. I'm sure this have been posted before. Any tips. Was working fine before I had some new tunes put on the truck. 2013 F350
Old Oct 31, 2024 | 05:14 AM
The Bone's Avatar
The Bone
I had to replace my camera and it's NOT cheap. I first replaced the wire harness. I also had to replace the chrome thing that holds the camera but not necessary because there is a hold down with a screw. You have to brake the hold down tabs to remove old camera. Take care removing the blue oval so you don't brake it. Comes off easy. Little spot on the bottom where you can use a small screwdriver to pry it off. You can buy cheap ones online but they are not all the same. Read the other threads on replacing the camera. I am sure there are some on here.
Old Oct 31, 2024 | 07:18 AM
Overkill2's Avatar
Overkill2
Mine currently stopped working, been like that for awhile now. I went into settings and shut it off for now. It was already replaced under warranty, now expired, so it appears they are garbage. I even put the electrical corrosion stuff electricians use on the plug. Complete junk...
John McK
Apr 27, 2024 12:49 PM
Thrill Family 4
May 3, 2023 09:26 PM
Johnsonaz
Dec 31, 2021 08:20 AM
NWnative
Nov 9, 2021 06:47 AM
willtim1234
Apr 4, 2016 09:53 PM
