80 mph speed limit on my f250 2011
Old Jul 29, 2024 | 08:18 PM
ford6.0kshah's Avatar
ford6.0kshah
6th Gear
Truck doesn’t let me go past 80mph. I tried looking in forscan but don’t see any speed limit option. I disabled my key still nothing. And I don’t wanna mess around with as built data without guidance. Truck is tuned I bought it like that no idea what tune or tuner.
Old Jul 30, 2024 | 06:16 AM
senix's Avatar
senix
then that tuner is your problem. A deleted truck with no factory tune or the tuner or a monitor for the vitals was your mistake.
And of course I am sure you don't have the DPF/SCR either. Probably don't have the EGR/EGR Cooler.
At least get a monitor so you can keep an eye on EGT's and actual trans, engine temps.
Old Jul 30, 2024 | 02:04 PM
ford6.0kshah
6th Gear
ya can u tell me which parameters to monitor.
also I bought the truck from an auction and found out after it was tuned
Old Jul 30, 2024 | 02:19 PM
senix's Avatar
senix
EGT's Getting up around 800-900 is what I would want to watch, can go as high as the 1100.
Coolant 225 and the fan should kick on high and sound like an airplane. You could let that get up around 235F before I was concerned.
Trans 200 to around 240
Oil temp up to 248F.
Old Jul 30, 2024 | 03:57 PM
ford6.0kshah
6th Gear
great thanks for letting me know. For now I’ll just my obd2 scanner to monitor these but what’s a good budget friendly monitor I can get off Amazon maybe.
Old Jul 30, 2024 | 04:03 PM
senix's Avatar
senix
I use a banks Idash myself. Bought directly from Banks.
Best support and warranty that way
Old Jul 30, 2024 | 04:13 PM
ford6.0kshah
6th Gear
Does easy lynk tuner have the capability to monitor these pids
Old Jul 31, 2024 | 12:49 PM
doczenith1's Avatar
doczenith1
For me the budget friendly path was an old Android tablet (or phone), the Torque Pro app and a Bluetooth ODB2 adapter. Despite the warnings from Torque Pro my sub $20 adapter has worked just fine.
Old Jul 31, 2024 | 04:34 PM
ford6.0kshah
6th Gear
great idea would a android device and forscan also work?
Old Aug 1, 2024 | 01:08 PM
doczenith1's Avatar
doczenith1
I don't know much about forscan. I think it only runs on Windows.
Old Aug 1, 2024 | 04:40 PM
Euroman's Avatar
Euroman
Forscan has got apps for iPhone and android. I use the iPhone app
Old Aug 1, 2024 | 07:17 PM
Overkill2's Avatar
Overkill2
Yes you can run FORscan on an Android as they have apps for it but I believe it's only to monitor not to get into the ECM to change settings like the speed. Here's a link to check out.
To get into the ECM, you'd need a laptop and Windows.
https://forscan.org/download.html
Old Aug 2, 2024 | 08:09 AM
Strider250's Avatar
Strider250
I run Forscan on a Microsoft Surface tablet.
Old Aug 2, 2024 | 10:31 AM
Overkill2's Avatar
Overkill2
Yep because it has Windows... do you just monitor PIDs or can you program as well? I'm no expert in this stuff. I was just going off of this chart.
chalngr
Jul 14, 2019 06:43 AM
garyleif
Dec 28, 2009 12:30 PM
cmc
May 2, 2009 12:36 PM
VoodooRacer
Apr 21, 2008 08:12 AM
superduty4x4
Mar 5, 2008 08:40 PM
