2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Speed limiter for 2019 F250
Old 07-03-2019, 12:10 PM
chalngr
chalngr is offline
chalngr is starting off with a positive reputation.
Hello everybody. Just joined here since I bought new F250 6.2 gas and got it in Finland..
I need speed limiter for it to get it registered in my coyntry.
Whats the best way to do it ?
Tuner ? And which one ?
Vcm 2 ?
Thanks in advance ..
Ps Im not able to get plates for it before its limited for registeration so little horry here 😅😅👍
Old 07-07-2019, 06:26 PM
RONMCHUGH's Avatar
RONMCHUGH
RONMCHUGH is offline
RONMCHUGH is starting off with a positive reputation.
I thought the limiter was built in to the truck and is adjustable using Forscan .
Old 07-07-2019, 07:00 PM
Krazy1
Krazy1 is offline
Krazy1 is starting off with a positive reputation.
I tried Forscan to turn off the limiter but it didn't work for me.
Old 07-07-2019, 07:46 PM
maypo59's Avatar
maypo59
maypo59 is offline
maypo59 is gaining momentum as a positive member of FTE.
It has a limiter already, do you need a certain speed setting?
Old 07-08-2019, 06:28 PM
RONMCHUGH's Avatar
RONMCHUGH
Is it something a dealer can do in IDS . I think they do it for some fleet vehicles .
Old 07-08-2019, 06:57 PM
Akley88
Akley88 is online now
Akley88 is gaining momentum as a positive member of FTE.
I believe 5 star can adjust it. It was an option when doing my tune on my 2016.
Old 07-08-2019, 07:15 PM
Krazy1
Krazy1 is offline
My dealer wouldn't do it for nothing. Libality of a lawsuit.
Old 07-08-2019, 08:27 PM
theboom
theboom is offline
theboom is starting off with a positive reputation.
Vcm 2 ?
Whats the law on this? A certain speed? I have never heard of something like this.
Old 07-11-2019, 01:24 PM
Anibal Medina
Anibal Medina is offline
Anibal Medina is starting off with a positive reputation.
you can also use the my key feature to set a speed limit , also forscan can do it too i have done it to a few trucks used by a company.
Old 07-11-2019, 02:03 PM
whagen
whagen is offline
whagen is starting off with a positive reputation.
I believe it's limited to 96 mph already from Ford. Do you need to limit to a lower speed? It states this some where in the owners manual.
Old 07-11-2019, 10:00 PM
Mikelikesit
Mikelikesit is offline
Mikelikesit is starting off with a positive reputation.
Its definitely limited to 96. Theres at least one other thread in here about that. Many have bumped into it....I think Forscan will not eliminate it. But it might lower it. However if Finland wants it limited. They will not allow a limit that you can change that easily.
If they accept 96 mph your good to go.
Old 07-11-2019, 11:23 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
It's been years but I remember in Finland when I visited it was a very odd speed limit like 80kph and up to 120kph in the summer outside of population.
Old 07-12-2019, 06:42 AM
whagen
whagen is offline
80 and 120, that's amazingly low! Would take forever to get any where at 80.
Old 07-12-2019, 09:05 AM
Robbgt's Avatar
Robbgt
Robbgt is offline
Robbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to behold
You could setup MyKey to limit max speed, though I think the minimum set speed is 65mph ~105kph
Old 07-12-2019, 09:10 AM
Todd157k's Avatar
Todd157k
Todd157k is online now
Todd157k is starting off with a positive reputation.
You can always put a wood block under the gas pedal. Thickness varies to speed desired.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
