start easy, warm up & die
Old Jun 14, 2024 | 07:18 PM
Push Ford over drive chevy's Avatar
2nd Gear
1994 Ford f150- odometer 306,000- 5.0L radiator cowling marked 1996 as if replaced & map sensor conversion. Gasket leaks, but no smoke, knock, etc.
Purchased about year ago. From towed home to easy bump starter crank (like new). No transmission issues other than pan gasket & rear seal leak).
1. General all purpose tune up.
2. New front fuel pump (rear tank no run) & filter
3. New distributor (hand timed)
4. Coil, sensors, ecm, catalytic converter5. New starter, battery, solenoid
6. Partial cleaned air intake gumout + 120 psi compressed air (not removed)7. New air hose intake8. New fuel pressure regulator9. Ignition switch new
Initially after easy crank, then 10 minutes of driving, while on freeway it would stall at 60 mph. If I shut key off & then back on (with or without activate starter) it would reprime.
The generic ecm failed and just replaced. Truck stolen, messed up key switch set for replace.
Now the problem up to now runs worse than ever. Will start quick pull out of driveway go 50 feet and die. May try motorcraft ecm. No other theft damage from incident.
Please help before I start shopping for a grenade.
Old Jun 17, 2024 | 11:22 AM
BlackBeautyFlareside's Avatar
Give the truck to the junkyard so someone can salvage some good parts off of it
Jun 14, 2024 07:20 PM
Duckf00t
May 19, 2021 06:07 PM
LRSTony
1997 - 2003 F150
Jun 11, 2015 03:40 PM
BCHauler
Apr 20, 2008 08:04 PM
900rider
19
Jun 26, 2005 03:22 AM
