Fuel Pump Plug has power but pump won’t work
photo of our work so far
- What year is this? makes a difference 84-85, 86-88 and 89-90
- You stated you don't hear the initial cycle up 2 second fuel prime up. I found that in my 86 that the only pump you really can hear is the Hpump (hi pres pump on rail) it's wierd that you have power at the low pres pump but plugged in you say not working however the relay does work.
- I think you should check the Hpump and it's connections (that is if you have 86-88) 86-88 There is a plug under the apron under the master cyclinder that has 1 hot wire in and 2 hot wires out - splits the power to both pumps (that plug gets greened out)
- You might have to learn how to ground out pin#6 on the ODB1 so you can turn key and fuel pumps will stay on so you can wiggle wires etc etc.
Once you have your jumper connected & the key on see if you have 12 volts at the inertia switch.
Heres how it's wired:
Pump relay to inertia switch on orange/light blue
Inertia switch to connector C160 on pink/black
Connector C160 to C161 & on to the pumps on black/pink.
Solid black is pump grounds
Solid orange is the fuel gauge ground.
BTW, the pump circuit only stays hot for 2 seconds each time you turn the key. Kinda hard to test in only 2 seconds. Thats why you need to see the link and run the jumper.
When you turn the ignition to Run, the fuel pumps should run for about 2 seconds and then shut off because no ignition reference pulses will be found because the engine is not running or cranking.
With the ignition key in Run, at the Fuel Pump Relay you should measure 12 volts on the small Red wire. This 12 volts comes from the ECC Power Relay.
On the Large Yellow wire you should measure 12 volts at all times. It comes from a fusible link that is attached to the starter solenoid lug on the battery side.
The EEC energizes the Fuel Pump Relay by grounding the small Tan/Light Green wire. When the relay energizes, 12 volts from the Large Yellow wire passes thru the relay to the Large Brown wire and then 12 volts is applied to the fuel pumps.
So if you ground the Tan/Light Green wire and start the engine and it runs, I'd say the computer is bad.
If you triggered the FP relay, and didn't hear the in tank pump run, then the problem is between the in line pump, and the in tank pump. Broken wire, crappy connection, or bad pump.
If your in-tank fuel pump is not running:
To rule that in or out, with the key ON/RUN jumper the DTC as you did before, and with a test light check for power at the in tank fuel pump. If you have power there, then your pump will need to be replaced. If you don't have power there, then you'll have to track back to the inertia switch and in between, to find a broken wire or bad connection.
Use a 5amp bulb, across power and a ground it should light up bright, now the same power to the pump ground, what does it do ?
Bright light = ground good, a dim or no light, ground at fault..
