Sponsored by: Real Truck
2016 f350 abs problem
Old Mar 6, 2024 | 08:05 AM
carlsson's Avatar
carlsson
I get an intermittent problem while driving, abs, traction control and brake warning lights come on, speedometer goes off for 15 seconds 0 mph), comes back on, but odometer stops and stays off also. "Check brake system" in display. Goes away after a while, but comes again often. Abs codes are c0031-13, c0037, and four others including a u0 that says no communication with instrument cluster, front left speed sensor, and rear left speed sensor. I believe there is only one rear speed sensor mounted near the rear differential which I have replaced with new Ford part. I'll post the other 4 codes momentarily. Thanks for any experienced advice!
c0040 brake fluid low, u0155 communication with cluster. Ive replaced the instrument cluster with two different used ones, but still get the same problem. The other two are both c0037 involving erratic signal left rear speed sender signal, which doesn't seem to exist on my truck.
2016 f350 dually 4wd, gas pickup
Old Mar 6, 2024 | 08:26 AM
Ginther's Avatar
Ginther
Check the big harness behind the e-brake bracket. Sometimes it gets loose and causes similar problems.
Old Sep 11, 2024 | 12:24 PM
austin78's Avatar
austin78
4wd High
did you ever find a fix I’m currently having same issue on my 2016
Old Sep 12, 2024 | 06:58 AM
carlsson's Avatar
carlsson
same issue abs
cause still not found, at mechanic now, replaced rear speed sensor again at his request, but sane issue now. he is going to check wiring in more detail and says could be that or abs module or even something inside differential.
Old Sep 12, 2024 | 07:52 AM
austin78's Avatar
austin78
4wd High
i keep getting the same code for rear sensor I’ve swapped it out 3 times and still nothing pulled the rear differential cover and everything looked fine. I’m waiting on new abs module to come in and will let you know if that fixes my issue.
flyingtexan
Mar 19, 2019 02:03 PM
PSD666
2009 - 2014 F150
Jul 12, 2015 09:18 PM
kystangbanger
Aug 5, 2010 07:35 AM
musclecars90
Apr 8, 2010 12:18 AM
93PGT
13
Jul 23, 2007 10:41 PM
