White smoke but no bubbles
Old Feb 29, 2024 | 10:44 PM
Vanhartman's Avatar
Vanhartman
Hey y’all so I went to start my engine (292) the other morning to enjoy the 70 degree weather, and as soon as I started the engine white smoke came straight out of the exhaust, and only grew as the engine got warmer. I turned the engine off and popped the radiator cap (it wasn’t too hot) and fluid came spilling out. I kept the cap off and when I ran the car there was no bubbles, as well as no oil mixing in with coolant. As I recall, leaks in the head gasket/block cause air bubbles and a mix of oil and coolant. Could this be a thermostat issue? Or something else I haven’t considered. Thanks
Old Mar 1, 2024 | 12:15 PM
f5fordgirl's Avatar
f5fordgirl
A lot of times the head gasket will start to go bad around a cyl, piston will suck in coolant and burn it, but you won't see any oil in the radiator.
aerocolorado
Aerostar
25
Feb 4, 2013 01:58 AM
Roll Tide
May 3, 2010 12:37 PM
markpl
Jul 1, 2009 09:56 AM
nativekid123
Oct 27, 2008 06:25 PM
ktplotts
Jun 26, 2006 06:37 PM
