Key Cylinder
Old Jan 16, 2024 | 01:07 PM
Koolaidman's Avatar
Koolaidman
2nd Gear
Key Cylinder
Hey guys I got a 1980 F150 and I have to replace a key cylinder. I got the old one out and have the new one. The old one came out with turning it to a run position and through a pin hole released the cylinder. My question is, I am trying to put the new one in I get it lined up but cannot get it to seat properly only goes about 3/4 way in. Any ideas if I I’m doing something wrong or any tips on how to get it to go in properly. Thanks in advance!
Old Jan 17, 2024 | 07:15 AM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
Are you sure the end that goes in is lined up with the part it fits into?
IIRC it is a slot type thing could the truck side moved and now the new key will not slip in?
Not seeing the old & new next to each other and where it needs to go it is hard to say do this or that.
That is all I have for now. Dont know when I can get to my books to see if it has something so keep trying.
Dave ----
Old Jan 17, 2024 | 11:06 AM
DirtyFerd's Avatar
DirtyFerd
If it's only going 3/4 in, then i suspect it's not lined up. If it goes almost all the way in, then it's just bad parts. I had this problem on my 91 Bronco. I bought the cheap lock and it wouldn't seat. I exchanged it, same problem. I bought the more expensive one with the same problem. I knew everything was lining up correctly. I put a micrometer on the end and it was slightly bigger. So i scraped and sanded on the end that goes into the actuator gear until it fit.
Old Jan 17, 2024 | 01:21 PM
Koolaidman's Avatar
Koolaidman
2nd Gear
It does fit and line up just won’t seat all the way in. I’m going to take a look and see if the new one is thicker on the end maybe that’s why it won’t go. I have a 71 that has the same issue went through 3 different cylinders and still have to start it with a screw driver lol.
Old Jan 17, 2024 | 07:48 PM
DirtyFerd's Avatar
DirtyFerd
Color the end of it with a sharpie. It'll leave witness marks that tell you where it's hitting. The tip is just pot metal so it scrapes and sands easily
PossumTruck
Mar 16, 2023 09:02 AM
jtindale
2004 - 2008 F150
Sep 8, 2012 10:01 PM
48fordf3
Oct 27, 2010 03:32 AM
easpilman
Apr 24, 2009 07:45 AM
75 SuperCab
Apr 3, 2006 11:51 PM
