ZF6 Trans fluid change
Old Jan 9, 2024 | 02:24 PM
Carter_1995's Avatar
Carter_1995
8th Gear
I know this may be a dumb question but I’m not a mechanic. I have 1999 7.3 with a zf6 trans. I have no clue when the trans fluid was changed last, it could have been years. My question- should I change it if it’s shifting fine? I wanna put fresh fluid in it but kinda scared because of all the people that say changing it after years can cause issues. So to change or not to change?
Old Jan 9, 2024 | 02:33 PM
Tpayne621's Avatar
Tpayne621
Thats in automatics they say that. Won't hurt anything at all to change fluid in manual trans.
Old Jan 9, 2024 | 02:34 PM
Carter_1995
8th Gear
Ahh okay. Thank you!
Old Jan 9, 2024 | 10:27 PM
Wes444's Avatar
Wes444
If you want to go thru the extra work and risk ripping the white shift boot and the black boot's fragile trim you can add an extra quart thru the top of the shifter. Some claim it's quieter, less gear rollover noise, runs cooler. I didn't really notice a change tho
Old Jan 10, 2024 | 08:56 AM
Tpayne621's Avatar
Tpayne621
Park it on a pretty good side hill with driver side high like in a ditch or soemthing and get the extra quart in through the fill plug.
Old Jan 10, 2024 | 08:59 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Loosen or remove the FILL plug before removing the drain plug. This may prevent you from having an oh crap moment if the fill plug is seized in place.
If it is, you can fill from the top as mentioned above if you find yourself in the oh crap zone.
Old Jan 10, 2024 | 09:47 AM
oharal's Avatar
oharal
All transmissions "shift fine" until they're slap worn out. They way to avoid premature wearing out is to perform regular maintenance. If you don't know if it was maintained regularly, it would not hurt to start doing so now!
Backwoods351
35
Aug 30, 2014 05:13 PM
hhowell1990
Jan 10, 2012 01:01 PM
electraglide
Jan 13, 2008 09:11 AM
bill99psd
15
Feb 23, 2007 09:35 AM
bokker
3.8 & 4.2L V6
Jun 8, 2006 09:50 AM
