What happened to this crankshaft?
Hey,
I bought a 5.4 2V core and took it apart. I noticed that the oil pump looked new and that the crank and rod bearings have wear. I think the engine had a oil pressure or oil supply problem in the crank drive.
My question is about one of the oil supply openings in the crank. It seems to be blocked by metal.
Is that metal in the drilling abrasive wear of a rod bearing? Or is it something else that blocked the drilling and caused an oil supply problem?
The other openings are not blocked.
thanks
thanks
The engine probably burned a little bit of oil and over time it got too low. This caused it to damage the bearings and the crankshaft which caused the engine to have low oil pressure. This is why someone swapped the oil pump out with a new one thinking that it would give it more oil pressure.
The crank is probably fine it just needs to be reground. Also take off the caps on the heads and inspect the cams. These can look a little rough yet work just fine but what you're looking for is one that's burned up.
The following 2 users liked this post by DaveMcLain:
The following users liked this post:
cradz350
6.7L Power Stroke Diesel
15
05-03-2022 10:35 PM
79F150EFI
08-27-2007 06:33 PM
