Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
P2195 on Ford 2010 Escape 2.5l XLT
Old Dec 26, 2023 | 11:01 AM
NYCUpTownGirl's Avatar
NYCUpTownGirl
3rd Gear
Unhappy P2195 on Ford 2010 Escape 2.5l XLT
I had a P2195 code and idling was bad. Idling would fall below 1000RPM to 500 and shut off. The mechanic checked for vacuum leak - none. He said the MAF and O2 sensor (upstream) had to be changed. Both sensors were changed. Idling was still bad but not as it was before. 2 days later I got the same code and now my car lurches forward and rpms drop to below 500 that caused the car to shut off 2X. HELP!!!
Old Dec 27, 2023 | 08:54 AM
scott91370's Avatar
scott91370
Long list of things that could cause this error: https://www.obd-codes.com/p2195
The page also gives some tips on how to diagnose which part may be causing the issue. Sounds like some torubleshooting was done my the mechanic but not enough.
Old Dec 27, 2023 | 10:00 AM
WHanson's Avatar
WHanson
Vacuum leak?
The codes indicate that the engine control believes the engine is running rich since the 02 sensor would be stuck or indicate lean.
You or the mechanic should double check for vacuum leaks as that is the most explainable cause given that the O2 and MAF sensors were already replaced and folks were working on the engine. You would be looking for a cracked or disconnected vacuum line. (Besides visual and audible whistling noise of a vacuum lead, YouTube has videos showing how this is done with a propane bottle and rubber hose while the engine is running.)
I’m believing that he did those successfully, but would be good to have the readout of the sensors to check that there wasn’t an oversight related to intermittent shorting lines of the O2 sensor as well.
Went724
Mar 3, 2016 04:53 AM
abadsarge
Jan 23, 2011 11:52 AM
Skoda
Modular V10 (6.8l)
15
Apr 11, 2009 07:57 AM
Nitramjr
General Automotive Discussion
Feb 1, 2007 07:18 PM
speedhools
May 30, 2006 08:37 PM
