S&B body mounts regular cab
Old Dec 12, 2023 | 10:03 PM
materthegreater's Avatar
materthegreater
These things look pretty nice!
Funny thing is, the directions are backwards where they specify which bolt is for the driver side and passenger side for row 3.
The old ones were pretty squished but otherwise not as bad as I was expecting.
I was able to remove 4 of the old ones today, and installed the 3 new ones on the passenger side. I literally had to burn the rubber out for the front radiator mount on the passenger side. I'll likely have to do the same on the driver side. The bolt was rust welded to the sleeve that it slides through, so there was no way to get it out without cutting it apart and I couldn't do that until the rubber was out of the way.
Row 2 & 3 bolts thread into the lower cups so once I got them broken loose they came right out with the impact. The upper and lower cups were rusted together though, so it took some persuading to separate them.
Old Dec 13, 2023 | 11:45 AM
materthegreater
Finished installing the new ones today. A few more pictures:
P.S. ignore the rust... This is a plow truck
Old Dec 13, 2023 | 05:49 PM
Tpayne621's Avatar
Tpayne621
I put the same set on mine month or 2 back and thought the same thing. Then looked closer at the directions and it said some are assembled opposite and to put it back how it came. Looks like yours doesn't say that so they must have updated them.
Old Dec 13, 2023 | 06:31 PM
materthegreater
How do you like them?
Old Dec 13, 2023 | 06:33 PM
Tpayne621's Avatar
Tpayne621
Haven't drove it yet since I put them on. Doing a bunch of other stuff at same time 08 axles and coil spring swap in front. 08 interior. Big job. lol getting close to wrapping it all up though.
Old Dec 14, 2023 | 08:21 PM
materthegreater
My goodness you are ambitious! I just read your build thread, excellent work!
Old Dec 14, 2023 | 08:26 PM
Tpayne621's Avatar
Tpayne621
I enjoy wrenching. Sometimes I believe I do stuff just to have something to work on. lol
Old Dec 14, 2023 | 08:35 PM
materthegreater
Here's the old ones:
I'm pleased that the fenders aren't resting on the bumper now!
Old Dec 15, 2023 | 03:11 AM
John in OkieLand's Avatar
John in OkieLand
I just had all of my body mounts replaced, and the old ones looked pretty much like yours.
Crumbling bit of rubber.
I bought the synthetic silicone kind, wow, what a difference that made in cabin noise. no more thunk thunk.
Old Dec 16, 2023 | 03:24 AM
INFRNL's Avatar
INFRNL
Mine seem to be holding up fine after nearly 247K, but I will be looking into something like this for my project truck I think. I'll be mounting a 76 crewcab onto an 01 chassis. I think I researched and I can utilize the SD cab mounts/ bushings
kmjone00
Feb 1, 2025 07:57 PM
Truck4SF
Jul 7, 2023 02:19 PM
Brad Brown
May 9, 2022 08:04 PM
hail destroyer
Apr 29, 2016 05:03 PM
77FordDW
Jun 6, 2011 09:55 PM
