Found this in my valley, any ideas?
Old Dec 12, 2023 | 07:09 PM
jstihl's Avatar
jstihl
Hey guys I was cleaning out my valley the other day as I have a oil leak and found this ball bearing laying right in the first channel behind the hpop. Any ideas where this could have come from? I suspect that my oil leak is coming from the front cover where it mounts to the block underneath the hpop but the leak seems to have gotten worse so wasn't sure if this little ball bearing may have something to do with it or it may be just a coincidence.
Old Dec 12, 2023 | 07:39 PM
uglypitbull's Avatar
uglypitbull
I know there is a check ball in the HPOP where the IPR goes.....non serviceable plug area. I would think it wouldn't run if that were missing though.
Not sure how big the one is that goes in the front cover, as I haven't ever seen one.
Old Dec 12, 2023 | 08:01 PM
jstihl's Avatar
jstihl
I was thinking about the check ball that's in the block underneath the square plug right next to the front cover since that is very close to where my leak is. I don't think it's possible for that ball to make it's way out though, I've never seen it either
Old Dec 12, 2023 | 09:01 PM
uglypitbull
That one looks larger....
There are a few check ***** in the HPOP.....has it been out by a PO? Is that a plastic or metal check ball?
Old Dec 12, 2023 | 09:45 PM
udsuth78's Avatar
udsuth78
To small to be the short circuit valve ball. Could be non serviceable plug ball I suppose. I could see someone thinking they could pull the plug to fix a leak with the hpop still installed and promptly loosing the ball. Or it could just be from some punk kid and his Red Rider.
Old Dec 13, 2023 | 06:18 AM
jstihl's Avatar
jstihl
https://youtu.be/kwrolIvTop8
The check ball is metal. I replaced the hpop about a year ago with a brand new Bosch from riffraff. I have cleaned the valley many times since then but this ball all of a sudden showed up. Just weird, I suppose it could have made its way up there from the road.
Old Dec 13, 2023 | 08:03 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Everyone keeps talking about the ball..
I see 1/64th of a cup of coffee at todays prices.
But it may be a check ball or the ball out of the 3/8 inch ratchet socket lock that broke.
Zack_Copeland556
Jan 20, 2023 04:22 PM
eire49
13
Jul 5, 2022 08:33 AM
Supernesguy9000
Jun 4, 2022 07:50 AM
falcons172
Jan 16, 2022 07:23 PM
Dwightttt
Mar 23, 2016 10:27 PM
