Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Redoing the brakes
Old Nov 13, 2023 | 05:15 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Redoing the brakes
Couple things I learned today while redoing the brakes on my 2006 Escape.
- Everything is different on the front brakes if you have rear disc brakes.
- The caliper bracket bolts are 18mm.
- Not all socket sets include an 18mm socket.
- You can't break the caliper bracket bolts loose with a 3/8 drive ratchet.
- The front brake caliper slide pins are 7mm Allen with rear drum brakes.
- The front brake caliper slide pins are 9mm Allen with rear disc brakes.
- Not all Allen key sets include a 9mm.
- There are no Imperial measure tools that work on 18mm bolts, or 7mm and 9mm Allen fasteners.
- I think I am going to need a drink!
Old Nov 16, 2023 | 06:47 PM
got2bjoester's Avatar
got2bjoester
I recall the pain, and I will admit that some "wrench lube" was used in my case every time I did brakes.
Old Nov 26, 2023 | 08:58 AM
kshaw's Avatar
kshaw
Finding the 9mm hex was the hardest part for me. Found them at Sears before they closed and Harbor Freight.
atxshakey
Mar 7, 2022 05:55 PM
jniolon
Dec 20, 2017 06:19 AM
JTdesert
Mar 3, 2009 12:16 PM
White_Knight
Nov 23, 2003 03:17 PM
thomasm
Mar 4, 2003 02:33 PM
