Bolting up exhaust manifold
I sort of did that with one of my cars when I replaced the stock manifolds with aftermarket headers. I'm referring to the flange studs that the catalytic H-pipe would attach to. The stock manifolds had the pressed-in studs, while the headers had holes that required using bolts. That should work fine, as long as you have a way to hold the bolts steady on one side while you try to tighten the nut on the other. If you're drilling out the studs from the factory manifold, you could drill the holes slightly smaller so you have to press the new bolts in.
Received 3,213 Likes
on
bullnose1985
09-07-2022 05:24 PM
Blue50F-1
05-31-2013 09:32 AM
82airborne82
15
08-31-2010 11:38 AM
offroaderone
04-18-2004 10:25 AM
MudinMan19704x4
12-14-2003 05:44 PM
