Bolting up exhaust manifold
Old Oct 17, 2023 | 11:03 AM
Tommygun69's Avatar
Tommygun69
4th Gear
Say you had to drill out a exhaust manifold bolt completely out. Could someone use a bolt nut and lock washer to replace the one bolt?
Old Oct 25, 2023 | 10:06 AM
xlt4wd90's Avatar
xlt4wd90
I sort of did that with one of my cars when I replaced the stock manifolds with aftermarket headers. I'm referring to the flange studs that the catalytic H-pipe would attach to. The stock manifolds had the pressed-in studs, while the headers had holes that required using bolts. That should work fine, as long as you have a way to hold the bolts steady on one side while you try to tighten the nut on the other. If you're drilling out the studs from the factory manifold, you could drill the holes slightly smaller so you have to press the new bolts in.
Old Oct 25, 2023 | 10:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
if you have a flange off the head the manifold bolts to so you can get a nut and washer behind it, yes it will work fine.
bullnose1985
Sep 7, 2022 05:24 PM
Blue50F-1
May 31, 2013 09:32 AM
82airborne82
15
Aug 31, 2010 11:38 AM
offroaderone
Apr 18, 2004 10:25 AM
MudinMan19704x4
Dec 14, 2003 05:44 PM
