Sponsored by: Real Truck
NEED HELP A/C Issue With 2011 F-350 6.7
Old Aug 24, 2023 | 06:42 PM
jay27's Avatar
jay27
8th Gear
Hi , having an issue with a 2011 F-350 6.7 Diesel. I am unable to get the A/C to come on , sends code P0532
I did have a fan issue that was resolved , I initially thought that was the problem and since then I have changed the pressure transducer switch twice , replaced the pigtail with a Ford part , had the system charged , we manually engaged the A/C pump from the relay location , changed the relay etc
1. full system
2. changed switch
3, changed pigtail
4. replaced relay
5. replaced clutch fan
Does anyone know the pin locations in the pcm plug for the 3 wires going to the pressure switch? On my scanner I only ever see 0.01v on the switch and 0psi , never changes.
Has anyone experienced anything like this?
Old Aug 24, 2023 | 07:20 PM
projectSHO89's Avatar
projectSHO89
Yeah, you'll have to fix the ACP sensor issue in order for the A/C to work. Here's the schematic.
Old Aug 24, 2023 | 07:28 PM
jay27's Avatar
jay27
8th Gear
Thank you for the diagram!!
Old Aug 25, 2023 | 07:45 PM
jay27's Avatar
jay27
8th Gear
***FIXED*** Thanks again to projectSHO89 , the diagram really helped.
In case anyone else has experienced a similar situation...
I had a break in the violet/orange wire (31) Did a continuity test on the three wires , two had consistently tested fine but the other was sporatic then dead. Ran a test wire with alligator clips to verify and then ran new wire. Been a couple years since the truck had A/C.
2.3L_ranger_fan
Sep 6, 2008 10:59 PM
dongc1
Aug 1, 2005 10:24 PM
rlh
May 24, 2005 04:44 PM
theswagg
Jan 11, 2005 08:46 AM
