a/c problem
Old Sep 5, 2008 | 08:34 PM
2.3L_ranger_fan's Avatar
2.3L_ranger_fan
a/c problem
<TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">i recently put a new compressor kit on my 97 ford ranger 2.3 and im having problems with the low pressure switch. it keeps shorting out. i put gauges on it both high and low pressure are ok. i replaced the low pressure switch everything works normal for 10 minutes or so then it shorts out the new switch. does anyone would know what would be is causing that? or have a wiring diagram for the a/c system?
thanks!
</TD></TR></TBODY></TABLE>
Old Sep 6, 2008 | 12:04 PM
jimdandy's Avatar
jimdandy
The switch opens and closes a relay for compressor control. The relay may be your problem. Also, the switches are not that hard to damage if you overtighten. The relay is usually on the pass fender close to the accumulator. You can locate the relay by feeling or listening for the click as you short across the pressure switch, engine off, ignition on.jd
Old Sep 6, 2008 | 10:59 PM
projectSHO89's Avatar
projectSHO89
I find it improbable that the switch is "shorting out".
The cycling switch does NOT control a relay, the relay is controlled by the PCM and is opened only under WOT (or similar) conditions. The output of the cycling switch is in series with the high pressure switch, then through the normally closed contacts of the WOT relay and to the clutch coil.
What are your pressures?
Steve
mchurches
Jun 30, 2024 12:15 AM
Reginald56
26
Jan 22, 2010 04:44 PM
fireman1296
13
Dec 27, 2009 01:15 AM
Joks79
Dec 23, 2008 11:46 AM
xavierx
Jul 25, 2008 10:43 AM
