Electric Fan relay
Old Jul 31, 2005 | 07:09 PM
dongc1's Avatar
dongc1
Electric Fan relay
I have a temp switch in the heads and it will switch at about 185'. this will trigger a relay that turns on the fan. I want to set it up so that the fan will come on whenever the AC comes on as well. This will insure a good flow of air across the condenser if you are not moving.
Any one found an easy way to to do this?
Don
Old Jul 31, 2005 | 07:44 PM
Randy Jack's Avatar
Randy Jack
I use a relay on my electric fan also (Hayden p/n 3652). The temp switch just provides the relay with a ground to switch the juice on. Find a ground from the AC switch and pair it into the relay ground circuit - voila!
I patched in a dash switch to that same ground to turn on the fan whenever. Works great.
Old Jul 31, 2005 | 09:02 PM
51ford fan's Avatar
51ford fan
Wink
Check out the electronic fan controller made by Dakota Digital #PAC2000
http://www.dakotadigital.com/ I installed a dual fan assy on my darkside car(can't mention here) I hooked one fan to run with the engine temp senser. And the other fan runs with the A/C. The digital controller will allow both fans to run with the engine weather the A/c is on or off. I plan to purchase one myself soon, I talked witha guy at a car show that had one and he loved it.
Rod
Old Jul 31, 2005 | 09:33 PM
sdetweil's Avatar
sdetweil
Don
As Randy Jack says, the temp switch provides ground to the relay, providing power to the fan. On my son's truck, I added a second relay, using the power from the A/C clutch to switch another ground leg to the first relay.
So the first relay gets ground from 2 places,
1 from the temp switch, 1 from the A/C clutch driven relay
Sam
Old Jul 31, 2005 | 11:48 PM
53fatfndr's Avatar
53fatfndr
Painless wiring should have a kit you are looking for as well.......just another option.
Old Aug 1, 2005 | 10:24 PM
dongc1's Avatar
dongc1
Thanks
Thanks Sam.
I figured out how you did it with two relays. Found a couple of relays in the junk box and have it ready to install.
Don
MikeBlansfield
Oct 16, 2014 06:02 AM
1FastGambler
Oct 8, 2012 07:56 PM
Mrbiff
Oct 27, 2011 10:30 AM
old rat
Sep 11, 2011 09:17 PM
trike1946
Apr 26, 2006 11:38 PM
