HELP, STRANDED, 2019 6.7 F-250 no crank
I need some instructions fast as my truck is in the middle of the driveway.
The story:
I was diagnosing my horn which doesn't work. Checked all the connectors for BCM one by one etc. nothing that special. Well, after stopping the diagnostics the truck doesn't crank at all. Is there a voltage limit or something that it doesn't even try to start if it's too low? My scanner is showing 11.5v.
I'm out of ideas. When unplugging the BCM does it lose some information or something? All the plugs went in nicely and the locking mechanisms down all the way. Did like five rounds to make sure it's not just a loose connector.
Please help, need to get the truck out of the way and I can't even push it ... What a day... Didn't even find the cause for the horn not working :/
So try jumping it.
I'll leave it plugged in and report back when I have the voltage higher above 12v.
I would get the batteries charged the pull ground cables off and go for lunch come back and try again.
Good luck and post back with the fix.
Still nothing. All powers up normally, but no crank. I'm getting really frustrated as Monday is coming soon. The truck has never had any starting issues etc. I noticed that one of the connectors on the bcm had little water damage when unplugging but still think that it can't be the culprit. All I tried to do was to get my horn to work...
Did you use contact cleaner in/on the BCM connector? What did the BCM side look like? Corrosion can be a MF'r on/in modules.
Where did the water cone from? Is it rain/water intrusion or perhaps condensation from the AC?
You could have the batteries load tested as the voltage reading does not tell the whole story.
My Toyota loving neighbor came to see my distress and after hearing how great and reliable Toyotas are for a good ten minutes, he help me to push the truck out of the driveway. I wonder how much loves to tell the story to every Toyota soulmate...
Today I double-check every fuse in the car and then decided to remove the BCM for a closer look.
I found watermarks in one of the connectors in the one with the shortest leads that sticks to the upper part of the BCM. Well, three connection rods were broken. I do not have any reference charts for the connectors, or a link where to get them. The truck is a 2019 f250 6.7. So if the broken ones lead to items that prevents horn and startup, we've got gold! Man I wish there was a donate button here for all the best advice here after we get it back running again.. The problematic connector I believe is B220F.
B220F broken pins (inside the female connector at the moment)
Arrow is showing the problematic connector and that side is up in the footwell
I then decided to open the whole unit for water intrusion inside the module, but the inside was nice and bone dry. I did spray it with electric cleaner and brushed all watermarks from connectors, and put it back together.
2019 6.7 BCM F250
So the main task I cannot do without correct documentation is to check which pins are related to which function.
While searching the living beep out of all possible forums I noticed that many have had water intrusion into this area behind the dash. I suspected lowsy job from the last guy who changed the windshield, as the water seems to sleep from the above.
I wonder what kind of MacGyver scorcery I need to do to get this thing moving... Module board pin extenders are really not a common thing.
I still do not think that the both batteries would be toast at the same time without any type of indication and voltages being normal.
Another thing I noticed that currently when I try to crank, it doesn't show the glow plug light which I at least think it should even during summer.
2019 6.7 BCM F250
I measured today that even with the ignition turned on, I do not have power to the fuses in the power control module that are regarded as ECU fuses. Also, the glow plug light doesn't turn on which it does normally.
I really need some help in this one. Never had a car not running at least without knowing why.
I did a forscan test for the BCM and here are the results. The one on the screen is related to the start issue I think. B-1310 run start control
Forscan results
Please help, I really appreciate all help to get this running again.
