Exhaust Question and Part #
Old May 5, 2023 | 02:57 PM
tomkins's Avatar
tomkins
Hello, 1974 F250 2wd. Does anyone know the part # for the attachment piece at the rear of the vehicle that supports the exhaust pipe ? If what I have is not original, what does everyone use in its place ? Its hanging on by a thread, literally. Pic below my 2nd question.
Also, at the front where the exhaust connects to the manifold, I have a leak. I hope its the exhaust pipe gasket ( if thats what its called ) and not the actual manifold because those bolts are frozen. When taking it apart where it connects to the manifold, I assume the exhaust pipe just fits into the manifold and there a rubber gasket. Is it possible to replace this gasket / pull the exhaust pipe out to do so - without removing the entire manifold and its 8 frozen bolts ?
Old May 5, 2023 | 03:18 PM
1TonBasecamp's Avatar
1TonBasecamp
The rear part is typically referred to as an “exhaust hanger”.
They may go by different names in official literature, but if you say exhaust hanger, everyone will know what you’re talking about.
Although there are multiple and many different styles, the one you have is probably the most common and was in use for 40 years and probably more. And probably still is…
it looks like an aftermarket one rather than original at least to me. But the good news is it’s probably available at any reasonably well stocked auto parts store still certainly had an exhaust shop.
I can’t say for your year truck, but many of them in later 70s didn’t use a gasket or “doughnut“ between the pipe and the manifold.
The manifold had a dome shape outlet and the tube had a female flare that slipped around it.
some earlier styles used exhaust “packing“ or donuts made of heat resistant material.
I’m guessing yours is the former style with the dome and the flange. But someone else here that’s more familiar with you or your truck will know for sure.
Or you might be able to tell just by looking.
Old May 5, 2023 | 06:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Also, at the front where the exhaust connects to the manifold, I have a leak. I hope its the exhaust pipe gasket ( if thats what its called ) and not the actual manifold because those bolts are frozen. When taking it apart where it connects to the manifold.
I assume the exhaust pipe just fits into the manifold and there a rubber gasket. It's not rubber! Is it possible to replace this gasket / pull the exhaust pipe out to do so - without removing the entire manifold.
There are 3 different exhaust inlet pipe to manifold donut type gaskets, what size is the engine?
Go to an auto parts store or a muffler shop t and get a new exhaust pipe hanger. The original Ford type are obsolete and there's a gazillion different ones.
Old May 5, 2023 | 06:50 PM
tomkins's Avatar
tomkins
Thanks Bill. Just went to O'Reilly and got a hanger, no worries there. I have the 360 engine.
Old May 5, 2023 | 07:04 PM
NumberDummy
C6TZ-9450-B .. Inlet Pipe to Exhaust Manifold 'donut' Gasket / 2 3/4" O.D. x 2 1/4" I.D. x 9/16" thick / Obsolete
1966/67 F100 352 w/Thermactor Emission (smog pump) // 1968/76 F100/350 360/390.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959
Old May 5, 2023 | 10:03 PM
tomkins's Avatar
tomkins
Thank you again. Is this the same thing ? :
Amazon Amazon
Old May 6, 2023 | 11:47 AM
NumberDummy
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Probably not.
Old May 7, 2023 | 04:21 PM
tomkins's Avatar
tomkins
So I was able to get the bolts off and have a couple more questions, thanks for everyones help thus far.
1) One of the studs came out of the manifold along with its nuts during removal. See photo. I can obviously measure length but if there is a part # or intel on what its replacement is, I would appreciate it. I not finding it by looking up the part # listed in the shop manual ( 376699-S2)
2) How do you separate the exhaust pipe from the manifold and remove old gasket and place new one in there? It has a very small amount of wiggle room. Is the only way to detach all of the exhaust hangers ? Would that even work considering its a Y pipe and the other side ( drivers ) side is still attached to the manifold ?
3 ) Last, to secure the pipe to the manifold, the studs go through a " plate " of some sort which pulls everything together. See photo with red circle. Mine is all beat up and broken and had several washers being used. Again, part # or info ?
Thanks to all, Im a rookie but learning a lot.
Ryan
twoodworth77
Mar 23, 2021 09:17 AM
dmueller71
Jul 13, 2018 11:56 AM
nix4x4
Aug 20, 2013 08:40 PM
jseim44
Jan 10, 2006 09:11 PM
