95 7.3 Belt and Front end issues
Old May 2, 2023 | 09:37 PM
Beaufort2012's Avatar
Beaufort2012
4wd High
So my 95 7.3 zf5 has an obvious belt squeal. I took some JB and lightly sprayed both sides of the belt, and found the grooves side was causing the squeak.
does that entail a bad belt?
My truck also has some front end sag, I believe, because it’s got some pretty bad camber. The rake is about 2 3/4 inches, 36 in from ground to top of front wheel well, 38 3/4 from ground to top of rear wheel well. I wanted to level my truck and fit 33s, but i don’t know if i got new springs if it would level out, or if I should also get a 2” add a leaf.
Old May 3, 2023 | 01:40 AM
Prototypemech's Avatar
Prototypemech
Powerstroke or IDI. 1995 should be ps but I don't see the badge on your truck.
Old May 3, 2023 | 08:32 AM
manicmechanic007's Avatar
manicmechanic007
They made a shim kit for the crank pulley to fix that belt squeal on your 95
Beautiful truck
The shim kits had 4 or so shims in a bag
Look at ebay item # 182882055678 F2TZ-6B306-B
That problem was on 92-94 trucks and was fixed by 95 supposedly.
Good luck
007
Old May 3, 2023 | 10:32 AM
Beaufort2012
4wd High
truck was repainted missing badge
bowsniper
7.3L / 6.8L V8 Gasoline Engines
May 12, 2023 01:23 PM
Lyrik
Sep 8, 2022 03:59 PM
josh2j11
Jun 25, 2014 08:43 PM
wrdabney
Feb 1, 2011 12:19 PM
jeffdoerr
Jan 6, 2006 04:34 PM
