Need some Dually advice
Old Apr 30, 2023 | 03:23 PM
sandymane's Avatar
sandymane
1995 Ford F350 2WD Dually 7.5 E4OD 46K miles. BF Goodrich Commercial T/A All Season LT215/85/R16 Load E ALL 6 Tires same. Door jamb says 65 LBS COLD on all 6.
What is a good ride tire pressure be for non towing daily driving and what should tire pressure be for light towing a small tractor? Nothing heavy ever.
Any other Dually info or tips for a first time owner? Thank You Sandy
Old Apr 30, 2023 | 05:50 PM
Briansshop's Avatar
Briansshop
I had 36" tires on my CC. Ran 60F,30R. Never changed it if I was towing - car/open trailer.
Old Apr 30, 2023 | 06:04 PM
sandymane's Avatar
sandymane
Originally Posted by Briansshop
I had 36" tires on CC. Ran 60F,30R. Never changed it if I was towing - car/open trailer.
What pressures would you recommend for my tires and setup? Thanks
Old May 1, 2023 | 06:52 AM
Briansshop's Avatar
Briansshop
I'd prob start about the same. Maybe 5psi less f/r and see how it rides. Some guys talk about a few psi less on the rear inside tires compared to the out sides to account for crown in the road. I never did,but something to think about depending on the roads in your area.
Truck is nice! Would be really cool to convert to 4x4.
Old May 1, 2023 | 08:15 AM
Edgethis's Avatar
Edgethis
You might have to play around with the pressures a bit to find something that works for you. Running a lower pressure can help the ride a bit, but do you readily have the means to air it back up should you need to tow quickly?
Old May 1, 2023 | 08:46 AM
manicmechanic007's Avatar
manicmechanic007
Stick with the recommended pressure of 65
If you were an old fart with a bad back I would let you go as low as 50 om all 4
You run the risk of a blowout by running insufficient pressure in the rear
Those rear tires are not supposed to chaff or touch each other on the sidewall (at 30 they surely will)
Good luck
007
Old May 1, 2023 | 11:49 AM
shelbygt500_653hp's Avatar
shelbygt500_653hp
Sandy will trade my super cab F 250 with the 5.8 for your truck.
‘’my truck has 73k actual miles.almost new everything
don
Old May 1, 2023 | 11:55 AM
sandymane's Avatar
sandymane
Very tempting offer but, Old Brute here with 98K is a family main stay so I gotta pass. Thank you for the offer of a beautiful truck to trade me. Sandy
Old May 1, 2023 | 12:44 PM
shelbygt500_653hp
I’ll even throw the turtle in under the truck !
don
Old May 1, 2023 | 12:53 PM
sandymane's Avatar
sandymane
Now you're talking business. I only wish I could throw in my LONG GONE 07 GT500 instead of the 95 F350 for the turtle AND truck.
Old May 1, 2023 | 01:08 PM
shelbygt500_653hp
Wow, it’s your lucky day. I own a 2007 GT500
Old May 1, 2023 | 01:10 PM
sandymane's Avatar
sandymane
Very nice. Does the stack of TSB's come with it?
Old May 1, 2023 | 01:14 PM
shelbygt500_653hp
no, as luck would have it I retired as a Ford dealership employee and all TSB’s done
Not trying to steal your thread, I am very interested in your truck. PM me if you want to take this further.
Just spent $2300 in maintenance on the truck for and am having a new grill, new head light cover chrome pieces and headlamps being installed soon
its what I do. Spend money on vehicles
don
Old May 1, 2023 | 01:17 PM
sandymane's Avatar
sandymane
Not trying to steal your thread, I am very interested in your truck. PM me if you want to take this further]
don
Thanks don. I haven't put 10 miles on it yet. Give me some time with the dullay, as I might do anything.
Old May 1, 2023 | 01:28 PM
shelbygt500_653hp
will do sandy
don
