As stated above that is 1-2, 2-3, TC lock then 3-4. The edge monitors all have a significant delay on showing when the coverter locks. It is locking on what you feel is a second 3rd gear shift, the Edge is just slow to show that change.
Appreciate the feedback... from both of you expressing the answer
The only thing that made sense is the Edge had a long latency on reporting the lock
and the RPM "shift" feeling was the rpm loss from going from fluid drive to mechanical lock. saving 400 RPMs when it locked
It all looks normal, and yes the edge has a delay in showing lockup, it does it with my truck as well. These are pulse width modulated converter engagement, and I believe the edge is allowing time for it to be considered 100 percent engaged.
