1951 f1 hood hinge bolt question
Old Jan 30, 2023 | 11:49 AM
Eric1109's Avatar
Eric1109
I’m installing hood on my 51 f1. The hood mounting points have a threaded shoulder that the hinges slide over. I am bit confused as the bolts bought through Dennis carpenter also have a shoulder (see photo attached). According to them they are correct bolts. But the bolt shoulder combined with the hood shoulder is twice as wide as the thickness of the hinge arm. That makes for a sloppy fit. For whatever reason I can’t figure out is it supposed to be a sloppy fit. I would think i should only have one shoulder which is exact thickness of hinge arm. What am I missing.
Old Jan 30, 2023 | 03:04 PM
3twinridges's Avatar
3twinridges
The original bolts, are normal bolts with a drilled head for safety wire.
JB
Old Jan 30, 2023 | 03:20 PM
1949f1's Avatar
1949f1
My 49 is the same way I went to the hardware store and bought some more washers like that came with the bolts. Make sure you do tie them with safety wire using the holes drilled in them
Old Jan 30, 2023 | 04:16 PM
abe's Avatar
abe
Those are 53-55 or 56 hood hinge bolts with wave washers..
Old Jan 30, 2023 | 09:57 PM
Don T's Avatar
Don T
The bolts are also correct for a 49-51 Ford CAR!
Old Jan 31, 2023 | 02:51 AM
1949f1's Avatar
1949f1
They are what fit my 49F1 also but with a longer shoulder
Old Nov 8, 2023 | 06:33 PM
KirkF's Avatar
KirkF
So i've got the exact same problem. What is the solution everyone goes with?
The shoulder is way too wide with the bolts fully tightened. Its like there is a thick washer missing or something.
It makes the hinges floppy and loose.
Kirk
Old Nov 8, 2023 | 07:14 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It seems you may have the wrong bolts in the wrong places.
My Ford Documentation shows Ford Part 350357-S8 being used for 38-52 Trucks (Except COE) for the hood hinge bracket to cowl links links. This is a 1/4-28x3/8 Zinc Plated Hex Head Bolt with a hole through the head. There is no shoulder. These are accompanied by 33795-S7 1/4-28 Cadmium plated Nut and 1/4 Zinc plated split lock washer.
Also listed is Ford Part 351714-S7 being used 48-52 for the hood hinge to hood which is a 1/4-28x3/4 with a 17/64 long shoulder between the head and threads.
There is another thread here with some good information and pictures: https://www.ford-trucks.com/forums/1...es-1952-a.html
Old Nov 8, 2023 | 09:12 PM
52Flthed's Avatar
52Flthed
I had a similar problem a few weeks ago. And a lot of the same people above helped me on my thread.
As has been said those pictured are the wrong bolts. I bought the correct ones from Chuck Trucks LLC. Also Bob Selsam on eBay NJ parts had some. I don’t think they’re reproducing those ——the ones I bought look used or dead stock.
Old Nov 8, 2023 | 11:17 PM
KirkF's Avatar
KirkF
Thank you everyone.
. I had a look through the Chuck's trucks catalogue, and found a nice picture. Page 93
1bikenerd
Oct 5, 2024 08:02 PM
Eric1109
Jul 6, 2022 12:23 PM
leonharu
Jul 10, 2020 03:31 PM
hotrodbob51
Feb 25, 2013 09:46 PM
mechanicblue3
Sep 7, 2007 04:48 PM
