One Man door install and adjustment
So, here is how I got them on and adjusted them using the cherry picker. Has anyone done any other handy methods? When I did it many years ago I muscled it into place with the hinges attached to the door and used jack stands to help me hold it.
I used a gait belt to hold it to the cherry picker. A gait belt is wide and sturdy with a metal clasp to hold it in place. It worked great.
Getting the door into the hinges was a challenge. The lower one was difficult to line up. It was much easier the second door. Having a spud wrench helped lining up the bolts.
Next was aligning the door. It was sagging too much. I added some body shims on the bottom hinge to move it up a bit but it was still low.
I started with a jack stand then I thought of the cherry picker again. I used a tie down strap on the end of the door. That gave me fine adjustments to raise the back of the door.
Now at first, stupid me tried adjusting it with the top hinge tightened. Well of course that didn't work very well. Once I loosened the top hinge as well, I was able to get the adjustment I needed for the door to close smoothly.
The gaps are pretty good as well. Not perfect, but probably as good as they were in the 50's. Their tolerances weren't quite as tight as they are now.
I looked back at pictures and I installed the doors back in 2014. I used jack stands and a bench with lots of grunting and groaning as I muscled it into place. I'm not a super strong guy.
This worked, but the cherry picker was wonderful.
It's no fun getting old. Sometimes now I feel like Samson of the Bible after he had his strength taken from him!
Early on in my restoration I literally "hung" the doors on this temporary support. I was checking the fit prior to body work.
Built an attachment for the floor jack to install them once painted.
I build industrial control systems which entails working on flat subpanel, mounting components and wiring components. After I'm done doing that I have to install the panels in the enclosures. Some of these enclosures are rather big, 6'x4', or larger. I use my forklift and some custom made lifting straps with bent "L" hooks on the ends. Sometimes I don't have much room to maneuver the forklift so I have laid the sub-panels on my two post lift, raised it all the way up and then slide the prone enclosure on the floor under the sub-panel. I lower the sub-panel just above the enclosure, hook the straps to the sub-panel, lift the sub-panel up, push the lift arms out of the way and then lower the sub-panel into the enclosure. Wish I had pictures of how I do it, it's kind of hard to explain.
What gets me is I've done this kind of stuff all by myself for years but when I have help in the shop everything comes to a stop and no matter how many are in the shop they all stop what they're doing and come to "help" me so now I have 2-3 guys doing what I've done by myself for years.
