Transmission Dipstick - 351W with C6
Old Jan 24, 2023 | 06:07 PM
53FordTough's Avatar
53FordTough
7th Gear
Hoping someone here is also running a 351W with a C6 transmission. If so, can you please tell me the size of your transmission dipstick. I am pretty certain mine is incorrect. Thank you for your help!
Old Jan 24, 2023 | 08:15 PM
56panelford's Avatar
56panelford
I still have the C6 I was running before switching it out with an AOD. If it's the length you need I can measure it tomorrow..
Old Jan 24, 2023 | 08:19 PM
53FordTough
7th Gear
That would be awesome of you, thanks!
Old Jan 24, 2023 | 08:20 PM
53FordTough
7th Gear
that would be awesome of you, thanks!
Old Jan 24, 2023 | 08:43 PM
56panelford
I'll measure mine tomorrow but I did just Googled it and it says that the length is 20.25 inches..
https://www.bing.com/search?q=what+i...29c9&mkt=en-ca
Old Jan 24, 2023 | 09:51 PM
53FordTough
7th Gear
thanks for that info. All of my Google searches have thrown a few different sizes at me unfortunately. A couple different ones I found said 25 3/4” so I am not positive at this point.
Old Jan 24, 2023 | 09:54 PM
56panelford
I'll still measure the one I have tomorrow and post my findings..
Old Jan 25, 2023 | 07:20 AM
Dturk's Avatar
Dturk
Oil pan dipstick
Disregard previous posting; cannot delete.
Old Jan 25, 2023 | 09:36 AM
56panelford
Okay,I went out and measured the length of the dip stick that is on the C6 transmission I have which was out of a 1983 F150 attached to a 5.8 litre engine. depth of oil pan is 2 inches from the flat bottom to the top lip of pan. Dip stick tube measured from the casing to top of tube is 20-3/4 inches. The actual dip stick length is 25- 1/4 inches in length measured from under the cup of the handle. From the tip of the stick to the full mark is 2 inches.
I'm wondering if there could be a difference in lengths of the sticks depending what the transmissions came out of. Thinking one from a car might be shorter that one from a truck but as long as the stick and tube were a match things would be okay..
Old Jan 25, 2023 | 10:31 AM
53FordTough
7th Gear
this is awesome and exactly what I was looking for. I had seen the measurement of 25 3/4 inches come up a few times on the Internet searches and it looks like you are right on with that if that stick was a little more straight, so that makes sense to me. Thank you for taking the time to do this and sending me this info!
nitsua28
May 1, 2012 03:22 PM
angelblue23
Mar 7, 2009 10:55 PM
rjvaughan
Engine Swaps
31
Oct 14, 2007 06:32 AM
FLUSHED UP
Sep 30, 2007 10:15 PM
