Low Pressure in fuel rail. Have replaced everything
Old Jan 6, 2023 | 02:23 PM
popelol's Avatar
popelol
3rd Gear
Unhappy Low Pressure in fuel rail. Have replaced everything
Hello to all,
I have a 2013 Ford F-250 2 door 4WD, A while ago my truck stalled and and I hooked up my scan tool and realized the pressure in the fuel rail was low. Replaced the fuel filters thinking that this could be the issue and I had the same problem. Next, I took off the HPFP and noticed that it had metal debris where the Fuel Volume Control Valve is, so I decided to replace the HPFP, replaced the lines, and the injectors as well (Bosch Injectors),Replaced the Fuel Pressure Regulator valve, Plugged in scan tool and inputted the codes on the injectors into the ECM. I crank the truck up and I'm getting no pressure still. To make a long story short, I ended up warrantying the pump thinking it was bad and the injectors as well, cranked the truck and it started right up with good pressure showing on the scan tool, I left it running for a while and I decided to turn it off and now it wouldn't start because of low pressure... again. I am really getting frustrated because I have replaced everything and somehow it still doesn't build enough pressure in the fuel rail. Any thoughts or help would be greatly appreciated.
Old Jan 6, 2023 | 02:47 PM
farmert's Avatar
farmert
Do you by chance use fuel additive? There have been reports of the foil seal on top of the bottle getting into the fuel tank, and it is the right size to block the fuel pickup. I have never had this problem, just reporting what others have said.
Old Jan 6, 2023 | 03:04 PM
popelol's Avatar
popelol
3rd Gear
I have not used any additives, I should also mention I have measure the low pressure side and it seems to be adequate.
Old Jan 6, 2023 | 04:37 PM
colossians3:23's Avatar
colossians3:23
You said you replaced the fuel lines, does that include both fuel rails as well?
Old Jan 7, 2023 | 07:49 AM
popelol's Avatar
popelol
3rd Gear
Well, now that I think of it that is the only thing left to replace. Could this cause my issue?
Old Jan 7, 2023 | 09:24 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Yup, there was most likely metal still inside the rails, and if you didn't change those some of that metal most likely went right into your new injectors. From what I understand, when a CP4 grenades, the entire fuel system is replaced (maybe just a good wash and rinse of the tank). By just replacing some of the things, you probably contaminated your entire system again...
I know it doesn't help right now, but once you get this figured out, I would consider installing a DPK kit too. It won't prevent a CP4 from blowing up, but it will protect the rest of the fuel system if it does, leaving you to just replace the CP4 and not every other component of the fuel system.
Old Jan 7, 2023 | 10:55 AM
speakerfritz's Avatar
speakerfritz
I don’t think that is possible. The tank draw straw has what looks like an inverter funnel with a screen over it. The area of the screen is about the size of a coffee cup lid. A half inch foil seal from a bottle would not clog it up. Maybe 25 of them being sucked up at the same time.
Old Jan 7, 2023 | 10:57 AM
speakerfritz
Hello to all,
I saw a YouTube video that medicated the drivers side fuel rail has a connection from the. The pax side and debris from metal contamination can accumulate in the rail and stop fuel flow. No fix but to replace the fuel rail. Reader h this.
Old Jan 7, 2023 | 11:45 AM
ToMang07's Avatar
ToMang07
Unfortunately... ^that is most likely the issue. If there was still metal in the system, you likely damaged the new parts.
Old Jan 7, 2023 | 01:21 PM
colossians3:23
Absolutely, Ive seen it happen before. The smallest metal debris will stay trapped in the rails and can cause issues. I would replace both the drivers side rail assembly (comes with brand new FRP sensor and FRP regulator) and passenger side rail and that might do the trick
Odds are your new injectors will be fine, the metal debris kind of acts like gold flakes in a creek bed, although Id keep those fingers crossed
terrymargate
6.7L Power Stroke Diesel
May 8, 2018 11:32 PM
bmxerbrett
21
May 15, 2016 03:04 PM
troy676
1983 - 2012 Ranger & B-Series
Dec 13, 2013 09:50 AM
GummyF250
Jan 17, 2010 06:45 AM
GILL353
Bronco II
Dec 4, 2003 05:29 PM
