Defrost and floor vent problem
Old Nov 24, 2022 | 06:02 PM
Thomas460's Avatar
Thomas460
Trailering
Hi, I got a problem with the defrost and floor vent were it been broken by where the clip is it and i am trying to find a easier way to replace it without take the dash off to towards it. It on a 1991 ford f150. The vaccum actuator works fine but the clip to the vent is broken.
Old Nov 26, 2022 | 09:16 AM
jas88's Avatar
jas88
I would just tape it using that foil tape.
Old Nov 26, 2022 | 02:47 PM
Thomas460's Avatar
Thomas460
Trailering
ya but the clip is connected to the actuator but it not connected to to the vent. I can see the clip right on out but nothing happens to the vent. So what ever connect that yellow/white clip to the vent to move is broken.
Old Nov 26, 2022 | 03:38 PM
AuroraGirl's Avatar
AuroraGirl
Wtf is the vent you speak of .If you want to quick dicking around and send a picture that would help us help you
Old Nov 26, 2022 | 06:40 PM
Thomas460's Avatar
Thomas460
Trailering
got a diagram of it but number 18 this sits behind your cab controls and your radio. It controls your air flow from defrost to floor or both.
Old Nov 27, 2022 | 09:04 AM
jas88's Avatar
jas88
OK your terminology is incorrect and it is confusing people. #18 is called a 'door'. I thought you were talking about the piece that goes on the bottom of the airbox and directs air to your feet.
A pic of what you have would sure help a lot.
Old Nov 27, 2022 | 07:51 PM
AuroraGirl's Avatar
AuroraGirl
it almost sounds like he means the connection between the door and the arm of the vacuum actuator , if that year is the same as mine, which means that it would be a matter of jb weld the broken part but hopefully he will show
