First of all, thanks for taking time to read and hopefully respond to this newbie question. I have been poking around the various sites looking for a mid 50's F100. I have found a prospect not too far away. A 1955 with a replacement 292 V8, three speed manual. The owner isn't sure about gears, but I suspect it still has the 3.92 rear and as far as I can figure, RPM at highway speeds is going to be higher than optimal. I figure about 2885 at 60 MPH and 3365 at 70 MPH. I am looking for a set up that will offer lower RPM for those times I have to be on the main roads. I don't mind the three speed manual but I could live with an automatic with OD as well. Can someone who has addressed this problem offer some advice? I confess I will have to hire this work done so it would be a good idea for me to know what I want before going ahead with any purchase and trying to find somebody to make the change for me. Thanks again and I apologize if this topic been beaten to death before.
If you’re keeping it original as possible install a 3.73 ring and pinion and find a three speed with O/D. It will reduce your RPMs and up your gas mileage.
Verify your gear first just to make sure.
If you have to replace the differential carrier, it might be cheaper to get a whole new rear for the truck. That is what I ended up doing for my truck.
I like to keep things stock so I kept mine a Dana 60 (I have an F250). If you stay with your Dana 44, which is easier, you would need to find something 1972 or older due to width.
If you want to change completely.....well there are lots of options. It just depends on what you want to spend. I'm cheap in addition to liking to stay fairly stock.
20474824[/url]]Verify your gear first just to make sure.
Thanks everyone for the replies. I have a lot to study now and I appreciate the help.
I never tried.
I had an 86 F150 with a 5.0 EFI with a 9" limited slip. After rebuilding it twice I switched it out for an open carrier and never looked back.
The 9" in my 48 is also open.
as far as I know, they quit using the Dana 44 after 56.
The only reason the limited slip might an issue is that my garage sits on a slope above the driveway and the grassy area leading to it can be slick. I'm guessing this might be a problem, especially in the case of a truck with a fairly light rear end. The 68 GTO with Saf-T-Ttrack limited slip climbs up there just fine. So for now it seems I have a few options, replace just the differential carrier, replace with a whole new rear which would include changing the carrier to accommodate different gears, go with a Ford 9 using a 57-72 F100 set up or one of the various others I found on another post...Or investigate a Tremec 5 speed or automatic transmission with OD. Like Harrier said, it's all up to how much a guy wants to spend.
Reason: addition to original
Changing the rear end is going to be far less expensive and work than swapping the trans. Lots of options from changing the Dana carrier to a limited slip carrier and 3.50 (my choice if I'm going to the trouble to swap ratios) gears, to finding a 9" or even an Explorer rear. Those come factory commonly with a limited slip diff.
