Help picking correct ECU!
Old Jun 15, 2022 | 08:26 PM
Troylj's Avatar
Troylj
8th Gear
I’m new here and hoping I’m posting this in the right place. I’m needing help picking the correct ecu for my truck. It’s a 94 f150 5.8 e4od with push button 4wd, I don’t think it has MAF? I’ll try to add pictures but the number off my computer is f4tf-12a650-ta. Calibration code is 4-64h-r00. I’ve found several on eBay but the last letters are different. Any help is appreciated. Thank you
Old Jun 16, 2022 | 03:03 AM
wwhite's Avatar
wwhite
What is wrong with your computer?
Any EFI-SD48B hardware will work. LAW0 is the computer for that calibration code.
Other EFI-SD48B differences would be fueling for different altitudes, possibly torque differences depending on axle ratios.
If you want exact replacement, you must get a *-TA or LAW#.
Here is a thread with same calibration code as yours:
E4OD shifting too early, Code 633 present in 2WD truck... - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Jun 16, 2022 | 07:56 AM
Troylj's Avatar
Troylj
8th Gear
Thanks for the reply! My computer has water damage. Bad capacitors and a couple burnt tracer wires which is more than I want to mess with.
78ford400cid
1947 and Older Ford Trucks
Sep 22, 2021 09:40 AM
adgjqetuo
Sep 2, 2021 10:24 AM
SipiderMonkey
Aug 9, 2021 08:35 AM
Kenneth Maddux
Jun 9, 2021 10:59 PM
