New Mexico Chapter Join Chapter, Leader:
1953-1956 F100 Headliner
Old May 29, 2022 | 10:45 AM
Lawrence Petty's Avatar
Lawrence Petty
Can someone give me tricks/hints to installing Rod Doors ABS headliner. Need to dry fit it so can mark dome light hole, speaker screw hole and seat belt holes before painting it. Don't want to break the tabs off or learn new cuss words. Just seems that the tabs are too tight on the ABS headliner to slip on without damaging something. Perhaps there is a trick to opening tabs up with something and the being able to pull that something out once the tab is started. Plus hear that you install front tabs first, then side tabs and the another says you do the side tabs first and slide headliner onto front tabs. Any help is appreciated.
AlsRyd66
16
May 13, 2019 09:50 AM
Tushy
Nov 16, 2015 02:20 PM
biggut
Jul 1, 2010 11:36 AM
Purple55
Apr 3, 2006 07:56 PM
imlowr2
32
Feb 3, 2006 06:34 PM
