E4OD not shifting properly. (Gear selector issue, not transmission)
Old Apr 10, 2022 | 10:52 AM
asa67_stang's Avatar
asa67_stang
'93 F150, 4.9L E4OD, 2WD
The tube that sits on top of the steering column broke, I replaced it. Following that the truck wouldn't want to fully go into park, when parked on an incline the parking pawl wouldn't hold and it would roll back while popping the pawl.
I followed this how-to on adjusting the linkage and it didn't really help. I was able to get park, but it won't go into 2nd or 1st gear.
Anyone have any ideas what might be up?
Old Apr 11, 2022 | 08:13 AM
jas88's Avatar
jas88
You replaced the tube? Or the entire column?
Old Apr 11, 2022 | 09:31 AM
asa67_stang
The outer tube had cracked as they sometimes do, I replaced it and the inner shaft because I was in there. Also replaced the bushings. Swapped over the pivot points and the gear selector handle.
Old Apr 12, 2022 | 09:06 AM
jas88's Avatar
jas88
Are you able to get to all gears by hand from underneath with the linkage disconnected?
Old Apr 12, 2022 | 05:42 PM
asa67_stang
Yes.
Apparently that's too short of a message and I have to have at least 10 characters in my reply.
Old Apr 14, 2022 | 09:08 AM
jas88's Avatar
jas88
Yes.
OK so it's not your trans. Your column or linkage is jacked up. Perhaps the repair to the column was not correctly done?
Old Apr 14, 2022 | 11:32 AM
pern21db's Avatar
pern21db
Did the cable get snagged on something when re-installing the column?
ExcellentRed
Jul 25, 2004 03:59 PM
csft
Jun 10, 2004 11:21 AM
92 f150300six
Jan 15, 2004 06:13 PM
ExcellentRed
Jul 5, 2003 05:22 PM
