5 speed conversion
Old Feb 7, 2022 | 12:22 PM
464Saloon's Avatar
464Saloon
5 speed conversion
Excuse me if this has been taken up before but I couldn't find anything with the search. Has anyone converted their original 3 speed to a late model 5 speed behind their Flathead V8? Seems I heard this had been done years ago but I wasn't in the position to do it at the time. Now I can't seem to find anything just automatics. Would like a 5 speed that comes out through the floor like original if possible. Thanks
Old Feb 7, 2022 | 03:59 PM
85e150's Avatar
85e150
I found a thread or two, but the links to the important stuff were gone.
Short version: The T5 from a Chevy S10 or GMC S15 works as the shifter pops up in the right place.
T5s can be fiddled with to swap the tail housing and move the shifter around, so you can use a Mustang T5 with an S10 tailshaft housing and shifter.
Starters- Flat-o Products, Inc.
https://www.5speeds.com/t5/
https://handhflatheads.com/product/tc5-adapter-kit/
https://www.moderndriveline.com/shop...adapter-plate/
If you search "T5 to flathead" you will find tons more.
Old Feb 7, 2022 | 04:44 PM
464Saloon's Avatar
464Saloon
Thank you, i did a quick glance around and will look more when I have some more time. I didn't see anything about transmission mounting. Do you know anything about that?
Old Feb 7, 2022 | 05:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The rear mount is the "big deal". The original trans crossmember has to be cut away in the middle, and either modified or replaced. Some examples...
Old Feb 8, 2022 | 10:17 AM
Carbonarc's Avatar
Carbonarc
Hi Rob,
I did this conversion on my ‘53 using Modern Driveline (MDL) components and a new T5 from them. If you’re putting this in your ‘55 F100 I’ll post photos and note some pitfalls that may save you some trouble.
Old Feb 8, 2022 | 10:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I assumed this was about a 48 -52, can you clarify?
Old Feb 8, 2022 | 12:10 PM
464Saloon's Avatar
464Saloon
Originally Posted by Carbonarc
Hi Rob,
Thank you. It is for my 51. My 55 has the 3 spd with the BW OD so its good.
Old Feb 8, 2022 | 12:11 PM
464Saloon's Avatar
464Saloon
Yes its for the 51.
464Saloon's Avatar
464Saloon
Thank you this is helpful
Old Feb 8, 2022 | 05:20 PM
Rembrant's Avatar
Rembrant
My '52 M1 had a 1987 Chevy S10 5spd in it when I bought it. I have since removed it as I'm swapping in a SBF and 4R70W. I don't have many pics of the interior, but here's one that shows where the shifter was located. I have some pics of how the trans was mounted, but nothing exotic...homemade crossmember.
Old Feb 8, 2022 | 06:21 PM
464Saloon's Avatar
464Saloon
Do you still have the parts? Were you thinking about selling them?
Old Feb 8, 2022 | 10:30 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Check out this thread. Especially post #4 https://www.fordbarn.com/forum/showt...=t5+conversion
Old Feb 9, 2022 | 10:24 AM
464Saloon's Avatar
464Saloon
Appreciate this but I'm leaving the 41 with the 3 speed. Its the 51 I want to convert
Old Feb 9, 2022 | 04:56 PM
Rembrant's Avatar
Rembrant
No, sorry. I listed everything locally and it all sold within 24hrs.
Old Feb 9, 2022 | 08:17 PM
33ratrod's Avatar
33ratrod
I just did this to my 51. Had a 4 speed and changed it to a T-5 Trans. Used a Cornhusker bellhousing, took some modifying to get it to work but worked great. Used the stock 11inch flywheel and pressure plate with an 11inch clutch plate from a Astro van. Put an after market bolt in cross member
