Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Need advice "right tool for the job"
Old Jan 29, 2022 | 06:50 AM
mikren's Avatar
mikren
Quick back story...im a shaftman in the mines. We often need to change brackets that hold the shaft guides in place. These brackets are bolted down to divider timbers. The bolts are 3/4 ×12" We burn the head off the bolt and use a 3lb hammer with a punch to knock the bolt down through the timber. Brutally hard work as the bolts have been sitting in these wet timbers for years. We need a driver/hammer tool that can pound this bolt out. Thinking that some of you fine gentlemen would have ideas,tips and tool
suggestions for this particular task.
Looking forward to this discussion.
Old Jan 29, 2022 | 09:39 AM
*2fords*'s Avatar
*2fords*
On Barnwood Builders, they found they could use a palm naier and a piece of rebar to knock pins out of the timbers.
Maybe that would work for you. Or maybe move up to an air hammer, they have more oomph behind them.
Old Jan 30, 2022 | 08:12 AM
JWA's Avatar
JWA
Depending on the size fastener and the what size tool would be acceptable someone like Milwaukee, Bosch, Hilti, Metabo or any other higher quality tool manufacturer would have something usable? I'm thinking a small demolition hammer like brick mason use frequently? Check this out: Hilti Cordless Demo Hammer
I linked cordless as I don't know how more or less convenient that variation would be.
Old Jan 30, 2022 | 09:41 AM
mikren's Avatar
mikren
Both great ideas...the palm nailer would be nice and compact. Not sure if it would have the oomph needed but certainly worth a try.
the chipping hammer would also work.would hit a lot harder too I'm sure.
will check with our construction crew on getting both for a trial run and get the welder to man. some type of punch/guide for such hammering devices. Will follow up when something gets in the works tks fellas. Definitely has to be batterie operated.
Old Feb 4, 2022 | 12:03 AM
manicmechanic007's Avatar
manicmechanic007
Hercules makes a 10 amp and a 15 amp electric hammer
You will need a 12 inch shank to drive with right?
You may need to weld something up as a collar or to use as an extension
The 15 amp at china freight is a jackhammer style with a 1/1/8 shank (you could have your machine shop turn it down to 3/4)
It weighs 66 lbs and would hack the mission for sure
They also make smaller hand held ones that are 12 and 14 amps that might also work
The harbor freight stuff is cheap so buy the warranty and do not hesitate to return it
Old Feb 10, 2022 | 11:28 AM
Sylvia Burnett's Avatar
Sylvia Burnett
5th Gear
Well, I'm not a mining expert, but I can tell you what I would do (assuming the bolt is at least 12" long and not rusted too badly). The easiest way would be to have a tool or a machine bolt the nut back on, then back the nut all the way out, eliminate the nut, and put the bolt back in. The other way would be to freeze the bolt and cut the head off with a grinder. Then use a big C clamp to tap the bolt back through the timber. A third way would be to use a spirit level, measure the angle and hammer the bolt straight through.
Xraychris
Aug 27, 2020 04:50 PM
reluctantfiver
6.4L Power Stroke Diesel
Oct 27, 2019 04:27 PM
lvin4jc
42
Jan 23, 2011 11:58 PM
smitty7
15
Mar 31, 2004 04:19 PM
jmailand
Apr 9, 2002 01:07 AM
