Bed bolt
Old Aug 26, 2020 | 06:16 PM
Xraychris's Avatar
Xraychris
Bed bolt
I bought this bolt from Ecklers to fix my truck bed. What tool do I need? I have a 1978 Ford F-250 Ranger Camper Special.
Old Aug 26, 2020 | 06:31 PM
John89's Avatar
John89
A 3/8" or 1/2" drive ratchet maybe?
What is the diameter of the bolt?
I pulled an original bolt this weekend to look for replacements. It was a 1/2" bolt.
Old Aug 26, 2020 | 06:36 PM
Xraychris's Avatar
Xraychris
A 1/4" ratchet is too small, and a 3/8" is too large. I am not quite sure the diameter of the bolt. 3/8" maybe? I was hoping Someone had used these bed bolts before, and could tell me what tool they had used. I'm told the tool is called a square bit socket. But I don't want to buy a whole set of these sockets, they are like $60.00!
Old Aug 26, 2020 | 06:42 PM
Xraychris's Avatar
Xraychris
A 1/4" ratchet is too small, and a 3/8" is too large. I am not quite sure the diameter of the bolt. 3/8" maybe? I was hoping someone had used these bed bolts before, and could tell me what tool they had used. I'm told the tool is called a square bit socket. But I don't want to buy a whole set of these sockets, they are like $60.00!
(The new bolts are smaller in diameter than the originals)
Old Aug 26, 2020 | 07:36 PM
72rtchallenger's Avatar
72rtchallenger
You could buy an individual male pipe plug socket on ebay if you know the size you need ,,or just buy a piece of square stock at right size , cut it down an weld a nut on one end and make your own tool , or buy the newer ford bed bolts that use a torx head bolt style
Old Aug 27, 2020 | 03:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I would think that most chain auto parts stores have a tool loaner or tool rental program? I would ask them before I want and bought something.
Old Aug 27, 2020 | 04:50 PM
Xraychris's Avatar
Xraychris
Found a torx bit that fits without slipping. Gonna give it a whirl once I get enough help to put the bed back in place. Bed takes 4 people to lift! You wouldn't think a Torx would fit a square hole, but it does!
hasaford
Jul 28, 2020 03:57 PM
Millam
Sep 12, 2019 02:45 PM
tjdad62
Sep 18, 2014 01:54 PM
mirage820
Aug 1, 2004 06:01 PM
darkman
Mar 15, 2001 06:52 PM
