Sponsored by: Real Truck
2004 f350 5.4l triton, p0356 only below 20 deg f.
Old Jan 22, 2022 | 06:08 PM
Suther51's Avatar
Suther51
Could an intake manifold leak cause a p0356 code? Only happens below 20 degrees f. New sparkplug, New coil packs, have not hound evidence of a bad harness plug. Seems on some motors a vacuum leak can cause this code. At first drenching the coil packs and harness with silicone spray seemed to help but not so much now. Could the spray have affected a intake manafold leak? Any help much appreciated. TIA
Old Jan 22, 2022 | 06:25 PM
projectSHO89's Avatar
projectSHO89
A P035x DTC indicates an electrical circuit fault, in your case #6. Vacuum leaks would not be expected to cause this concern at all.
It's probably a circuit connection that gets cold and shrinks (everything shrinks in the cold, you know...) causing an open electrical circuit. Most likely suspect is the COP's connector.
RLGJ
1997 - 2003 F150
15
Jan 3, 2013 06:45 PM
handyandy91
1997 - 2003 F150
Jan 14, 2011 10:17 PM
CSFord
Escape & Escape Hybrid
Jan 3, 2008 11:10 AM
dagray3
24
Nov 30, 2007 11:43 AM
Monty06
Nov 21, 2006 03:36 PM
