Sponsored by: Real Truck
99 F250 Super Duty Blowing White Smoke on Start Up
Old Jan 22, 2022 | 12:07 PM
H.fisher's Avatar
H.fisher
I'm stumped. My 99 7.3 when I got it a couple months ago had no CEL and didn't want to start in the cold, but now it's throwing codes for EBPV, and 1211 and 1212, and 0603 (assuming because of the tuner I added), and 1280.
I recently changed glow plugs to get it to start in the cold, and changed IPR, ICP, and did a 5w40 oil change as weather here is getting to single digits. Still blows white smoke but no longer sputters and dies after startup like it used to.
I can't always plug it in because I don't always have access to the right parking spots at my apartment complex.
Old Jan 22, 2022 | 12:40 PM
bwguardian's Avatar
bwguardian
The 1211, 1212, and 1280 is an ICP issue. Did you replace the sensors with Ford Motorcraft units? Unplugging the ICP should make it default, so you might try that. What code are you getting for the EBPV?
Old Jan 22, 2022 | 01:08 PM
H.fisher's Avatar
H.fisher
Thank you. I replaced the ICP with Standard brand, and it came with a pigtail to replace the wiring. So I replaced the wiring and put in the new ICP but it didn't want to start up. I replaced the ICP with the old one and it started up. Code's still there though (1212). The EBPV codes are P0475 P0478 and P0470 for the EBPV. (Unless I'm mistaken)
Old Jan 22, 2022 | 02:20 PM
bwguardian's Avatar
bwguardian
You were getting the 1211 because it's an aftermarket unit which isn't compatible. The 1212 code is for wrong voltage...bad sensor. If you unplug the sensor it should default. Does the old sensor have oil in it? The EBPV codes could simply be a dirty sensor and/or clogged sensor tube, both of which can be cleaned. While you have the sensor out, ohm it to make certain it's good. Same with the tube as they typically get a hole in them that you can't see where they go down to connect to the passenger side exhaust manifold.
Old Jan 22, 2022 | 02:33 PM
H.fisher's Avatar
H.fisher
Well the 1211 code went away after I changed ICP sensors. I plan on cleaning the EBP tube out today. I checked the ICP sensor and it's totally dry, that's why i was comfortable using the old one again. The old one is the one in there now. It's throwing 1212 still though. I'm on my way to get a new glow plug relay now. Also, I don't have a multimeter to test the ohms unfortunately.
Old Jan 22, 2022 | 02:41 PM
bwguardian's Avatar
bwguardian
Go to Harbor Freight and pick up a cheap $5 ohm meter so you don't keep throwing parts at it. That way you can test the EBPV sensor as well as the GPR. Again, unplug the ICP and see if that 1212 code goes away...
Yougotthehit
Jan 22, 2011 11:21 AM
dieselhdrider
Oct 31, 2010 09:00 PM
jeffsk7
Mar 8, 2009 11:30 PM
Deiselman
22
Jan 23, 2007 08:32 AM
Big Sky
Feb 13, 2004 09:55 AM
