Oil & Lubrication
Transmission fluid change
Old Dec 3, 2021 | 07:22 AM
Mspangler's Avatar
Mspangler
4wd Low
So I was going to change the transmission fluid in my 4 speed 70s truck transmission because it had been sitting for a while, but my dad said not to drain it because it can mess with how the clutch works or something along those lines. I’ve never heard of such thing.
Old Dec 3, 2021 | 09:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Sorry, your dad has no idea what he's talking about.
Old Dec 3, 2021 | 10:48 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Sorry but that is along the line of:
never change oil and filters for the engine.....
never change the gear oil in the diffs either.
and for sure never grease the fittings.
Old Dec 4, 2021 | 07:40 AM
JWA's Avatar
JWA
Is this transmission an automatic or standard shift? If its an automatic NOT changing the fluid will definitely "mess with how the clutch works..........."-----guaranteed!
Old Dec 4, 2021 | 11:27 PM
Mark Kovalsky
I don't remember any four speed automatics in the 70's, so this has to be a manual trans.
The oil never touches the clutch in a manual transmission, so there is no way changing the oil could affect the clutch.
Old Dec 7, 2021 | 06:50 AM
DaveMcLain's Avatar
DaveMcLain
He's probably thinking of the synchronizers in the transmission. Those ARE sensitive to the type of lubricant that's used and some transmissions will not shift very well with the wrong type of gear lube.
Old May 13, 2022 | 10:20 PM
SDDL-UP's Avatar
SDDL-UP
Do NOT use a GL5 gear lube in any transmission with bronze synchros as it us corrosive to "yellow" metals.
WhiskeyNitro
2011 - 2019 Explorer
Apr 21, 2022 09:39 AM
g60patrol
Jan 31, 2007 07:33 AM
Starratt04
Feb 16, 2003 11:49 AM
dcrewchief
Aug 22, 2002 12:43 PM
