Real wheel bearing issue
Old Nov 6, 2021 | 07:45 PM
Rich Murphy's Avatar
Rich Murphy
Replaced rear inner/outer bearings, races, seals with timken products. Greased and lubed appropriately.
When I put the axle nut back on I can’t tighten it to spec. If I do I can’t spin the hub. I read in multiple threads to torque to 60 lb/ft and back off 5 clicks. Gets too tight to spin with less than 10 lb/ft!
I backed everything off and retightened until I have no play in the hub but can still spin it. It’s way under spec.
Either I have the wrong torque values or….
Greatly appreciate any help.
2001 7.3 Limited 4x4
Old Nov 6, 2021 | 08:25 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Factory service manual specs 60 ft lbs and back 5 clicks for new bearings, 7 for old bearings.
Old Nov 6, 2021 | 08:29 PM
pirate4x4_camo
The only issue i can spot based on your description is “ greased”
those bearings do not use grease they use differential gear oil.
“Fill the hub cavity with 29.6 ml (1 oz) of SAE
75W-140 High Performance Rear Axle Lubricant
FITZ-19580-B or equivalent meeting Ford
specification WSL-M2C192-A.“
Old Nov 8, 2021 | 06:32 AM
Rich Murphy
Solution:
I disassembled a wheel and triple checked the part number on the bearings. Used an old race to cross reference the part number to what was removed. All good. Noticed the inner bearing wasn’t shined up after installing the hub and giving her a spin. Tells me it wasn’t seated. Reinstalled the hub and tightened it as tight as I could muster then backed the nut off completely. Re-torqued and she spins fine. Just needed to get the seal seated better. Wasn’t aggressive enough with it.
Thank you for the comments.
drumfield
Jan 25, 2019 04:56 PM
1993 ford
Aug 15, 2017 09:35 PM
jpsage
Oct 19, 2010 01:45 AM
ac700wildcat
Apr 28, 2010 04:24 AM
CollinsCD
Dec 15, 2001 08:18 PM
