My 2014 all stock currently 76000 miles is intermittently giving multiple CEL codes. P132b and P1249 then I received and reduced engine power message after a fill up and getting back on freeway. Took truck into dealer and they also got a coded P134. They checked everything and said that the waste gate solenoid was not working correctly. They replaced and drove for about 20 miles no problem. I pickup the truck and as soon as I get on freeway reduced engine power message comes on.. I drive back to dealer leave truck running to show them. They diagnose the truck again and keep getting random codes. Every time they said they reprogram for that code and continue getting random codes. and reprogram. Said it is clear now but I am not sure it is fixed. Are they blowing smoke up my *** about reprogramming?
My truck has been to the dealer multiple times for CEL and Reduced Engine Power. Last week on way to dealer the truck went into limp mode but corrected by turning off and back on. Dealer has been able to reproduce errors and reduced power but cannot find anything wrong. They have been in contact with Ford Tech and their suggestion is the replace the turbo. Still waiting on that repair to be done very expensive. If that does not solve the issue I will be demanding for reimburse for repairs.
