1978 - 1996 Big Bronco
Removing headlights, turnsignals in a 96???
Old Nov 1, 2003 | 06:08 PM
merkstang's Avatar
merkstang
Question Removing headlights, turnsignals in a 96???
Im not sure how to remove the tunsignals and the headlight trim Ihave the top 2 screws off and not sure what holds the rest in?
Any help would be great!
Old Nov 1, 2003 | 06:18 PM
merkstang's Avatar
merkstang
Just found it in a search in the f 150 area
Old Nov 1, 2003 | 07:03 PM
greystreak92's Avatar
greystreak92
Yeah, but now that you know what needs to happen, its still a PITA to get to those two little nuts!
Old Nov 1, 2003 | 07:28 PM
merkstang's Avatar
merkstang
Well I needed to take out the windshield washer pump motor mine is shot, so it was easy for that side. Im off to AZ to get the pump and then Ill do the other side.
Man Im out in the garage and thinking " Dam I just cant leave anything alone!!" Im a mustang guy (user name) and now Im Nuts about the Bronco!! the StangNet guys have wondered where I am , and Im HERE! Doing Bronco Stuff!! I have a headUnit on the way and did the front speakers this week and the Rear shocks and brakes last week and this week is the Rad arm bushings and the Front shocks and Air bags(for plowing) and font brakes, Oh ya Im Undercoating as I go too!!!!!!!!!!!!!
Well off to AZ and then back to Tint the rest of the Lights, WOW It will look Cool!!! I guess thats what a Car guy does.... WHy would ANYONE want to look like everyone else????
Old Nov 1, 2003 | 08:41 PM
AYoungblood's Avatar
AYoungblood
Well how the heck do you adjust them?
I bought the tool to change the virtical angle but they wont budge.
Ive sprayed PB down the shaft 2 times and, really cant see anything else to spray. It all hidden.
Any idea?
Adam
Old Nov 1, 2003 | 11:37 PM
greystreak92
Youngblood,
Near the outer, upper corner (driver's side of the left headlamp and right side of the passenger's headlamp) there is a tiny, hex drive shaft sticking out from between the upper crossmember and the plastic of the bezel. I think its something ridiculous like 4mm or smaller. Give those a few twists and you will see the vertical focus begin to shift. The mechanism is actually a right angle gearing that runs an adjuster screw at the bottom of the headlamp assembly.
Old Nov 4, 2003 | 10:17 PM
AYoungblood
Thanks GS.
I tried to adjust it with a pair for very small vice grips. But it wouldnt budge. So i went to the local auto store (Murrays) and got the head light adjuster.
I cant even get these things to turn even a little.
Will I have to take the head light out?
Adam
Old Nov 5, 2003 | 01:01 AM
greystreak92
Possibly. I had to replace a headlamp assembly that the gearing for the adjuster had crawled out of its housing. The gearing consists of two plastic crown gears at a right angle to each other. The only drawback to this is the fact that I only know that because the gear housing had disintegrated. Normally the gearing is sealed inside the assembly. If you can remove the assembly you may be able to get some type of lubricant to seep down the adjuster shaft and into the housing to get things moving again.
john8403
Nov 11, 2010 06:45 AM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
farmalldude
Aug 28, 2008 07:51 PM
DABTX
May 25, 2008 05:06 PM
KennethKvittum
1997 - 2003 F150
Feb 20, 2006 09:04 PM
