turn key--no start but clicks
Old Jun 17, 2021 | 10:11 AM
cranegrad's Avatar
cranegrad
1995 F250 XLT 4x4. i played around with the shift lever and the truck started so i assumed the neutral switch was bad. changed it and still have the same problem. if i get the no-start i can turn the key on several times in a row and the truck will start. also i noticed that with the door open the chime doesn't come on unless i wiggle the cylinder around--not sure if that'll help with the diagnosis. thanks in advance for any help.
Old Jun 17, 2021 | 10:47 AM
SFaulken's Avatar
SFaulken
sounds like the ignition switch further down the column is either bad, or out of adjustment.
Old Jun 17, 2021 | 06:19 PM
wwhite's Avatar
wwhite
Bad ground at battery.
Clean both positive and negative terminals at battery, and check the starter solenoid for clean connections as well.
Several clicks in a row is the starter solenoid working, but is either bad connection, low battery, or starter going out the window.
Is it worse when it is warm, works fine when cold?
Old Jun 18, 2021 | 09:36 AM
subford's Avatar
subford
Sounds like a bad starter relay to me.
The starter relay on the passenger fender is making the clicking sound but its contacts are burnt and not pulling in the starter solenoid.
Could also be the spade is not making contact down on the starter solenoid.
Attachment 278676
Attachment 279755
Old Jun 18, 2021 | 12:11 PM
Jon Shannon's Avatar
Jon Shannon
Had the same issue with my 1997 F-350 last week. New starter relay solved the problem. Cheap and easy.
Old Jun 18, 2021 | 03:04 PM
GoinBoarding's Avatar
GoinBoarding
My truck has been doing the same at random. I first made sure my battery was still ok, and cleaned connections. They were both in great shape. Measured voltage drop between starter and battery during cranking, that checked out too. Starter spins over quickly when it does spin, and it's only a few years old, so I didn't think that was it. It continued to happen, so one of the times I popped the hood, jumped the starter relay, and it turned over like normal. I'll replace the starter relay one of these days.. But jumping the relay with the key on will keep me going if it happens again before I get to changing it.
Old Jun 18, 2021 | 07:05 PM
cranegrad's Avatar
cranegrad
yes--it was the starter relay. Thanks for the help.
Old Mar 5, 2022 | 05:22 PM
Wrnorth's Avatar
Wrnorth
4wd Low
Similar prob
Sorry for being late to the thread but it sounds like the problem I am having...I suspected a starter relay but can't find it, any one have a pic or a eatiled description of its location ... I did change the solenoid, starter, and the ignition switch and thought I had it locked for a few days but no...sorry forgot to add, mine us a 1996 f150
Old Mar 5, 2022 | 08:39 PM
subford's Avatar
subford
The starter relay:
Attachment 278553
Old Mar 5, 2022 | 11:25 PM
Moongypsy's Avatar
Moongypsy
Well now that you have the answer I'll say starter relay.. 🧐
Old Mar 8, 2022 | 06:42 AM
Wrnorth's Avatar
Wrnorth
4wd Low
Sorry for the delay guys, Cueto subfords post with the diagram that shows the solenoid and relay as separate things got confused 😊 ... Anywaysmy problem turned out to be the positive battery cable, replaced it and all is good...thanks for the help, much appreciated
Jared Rumple
Nov 28, 2021 09:21 PM
RGAllen1960
Apr 22, 2020 07:30 PM
kavik9
Mar 8, 2016 10:34 AM
Jklnhyd
Mar 14, 2014 10:27 PM
ckinneavy
Mar 8, 2003 09:26 PM
