95 amp to 130 amp alternator
Old Jun 16, 2021 | 08:38 PM
EB5.0's Avatar
EB5.0
I need a new alternator in my 1995 F-150 5.0L. It currently has the stock 95 amp alternator (I am assuming). Wanted to do a little upgrade on it and I found a 130 amp alternator made for a 1995 F-250 7.3L. It looks like the same exact alternator. They are both 3g alternators. Can I upgrade to the 130 amp alternator? Also, if I can use the 130 amp, do I have to upgrade the wiring from the alternator to the battery?
Old Jun 16, 2021 | 11:23 PM
Scndsin's Avatar
Scndsin
My first 130 I upgraded to I grabbed out of a 95 E-250/5.8 cargo van in a JY. Bolted in, plugged up the 95 amp original factory wire & went about my business.
Several years on when the bearings started getting noisy, I ordered a new Motorcraft unit for the same application.
No personal experience with the diesel applications, but if it's side mount, you should be able to plug & play.
One of these days I do plan on upgrading the harness.
Old Jun 17, 2021 | 12:02 PM
GoinBoarding's Avatar
GoinBoarding
On my '96 F150 with 5.8L, I swapped the stock alternator with the 130 amp from a '96 E350. Same as Scndsin: bolted in, done. I do have a winch, that was my motivation.
Old Jun 18, 2021 | 02:55 PM
timbersteel's Avatar
timbersteel
I did the same as Scsdin. I did upgrade the wiring though. It's only 6 or 8 gauge wire from the factory?? I put 2 AWG and a 175 amp megafuse between the alt and battery. Easy to do.
Done it to all 3 of my trucks.
Old Jun 18, 2021 | 06:32 PM
EB5.0's Avatar
EB5.0
​​​​​​Can you post a picture of the setup?
Old Jun 18, 2021 | 07:16 PM
timbersteel
Will do here shortly. Have to wait for my little ones to go to bed.
Old Jun 18, 2021 | 09:32 PM
timbersteel
Here are a few pics. It's dark, but I tried to get some good pics of the wire, megafuse, and battery.
I hope this helps. It really easy to change everything and there is no bottleneck from the factory 8 gauge wire with fusible link.
HaydukeLives
Aug 6, 2018 07:12 AM
marv02
13
Jun 22, 2017 10:39 AM
kyle j
Jan 28, 2013 09:51 PM
judge1971
Electrical Systems/Wiring
Jun 25, 2004 02:05 PM
